Posts837,997
Posts: 157 |
Can anyone give me any tips as to where Morgan might have hidden the relays on my car? And no, they're NOT on the bulkhead!
2011 +4 'LB' Indigo Blue, Heron trim Saab 9-3 1.8T Sportwagon
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
On 2011 ' s they are likely to be under the dash fairly central and screwed into the bulkhead frame.
On 2005's they are above the steering column.........
Posts: 157 |
Oh gods, could they have made them any harder to get at? Thanks for the tip :-)
Posts: 27,836 Likes: 763
Posts: 27,836 Likes: 763 |
It is not so difficult if you look under steering wheel you can see them
Posts: 14,009 |
It is not so difficult if you look under steering wheel you can see them Yes.....crawl into the car, turn over, lie down with your head in the footwell, torch between your teeth, and you'll find them.
Posts: 157 |
Is it worth taking the top of the footwell off to get to them? Only seems to be 4 screws holding it in place...
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
It is not so difficult if you look under steering wheel you can see them Yes.....crawl into the car, turn over, lie down with your head in the footwell, torch between your teeth, and you'll find them. Easy, but who gets you out again?
Posts: 1,511 Likes: 21
Posts: 1,511 Likes: 21 |
Keep mobile phone within reach !
Posts: 1,521 Likes: 61
Posts: 1,521 Likes: 61 |
The dashboard is held on my 4/4 by just three screws. one at either end and one high up, centrally lurking below the rubber top trim. Lower the adjustable steering column to its lowest travel, Remove undertray. lift off the dash complete with all its instruments and support the weight with string or something suitably wedged under. The relays are then obvious and easily accessible.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Or change to a 2003 "poverty model" 4/4; where all the fuses and relays are neatly located and easily accessible in a box under a the bonnet.
Bud 4/4 "Stanley"
