9 members (Montegue, gmcn, hillclimber, MJF, AlyMatt, Mark+4, TBM, Graham, G4FUJ, AndyGoff), 298 guests, and 82 robots.
Sagging Hood
Topics49,858
Posts837,463
#319778 17/11/15 05:50 PM
E
E
I have just had the crosshead chemically stripped of paint and rust prior to refurbishment. Now its back to bare steel I noticed some stamping on the top bracket where the Kingpin locates. the nearside is stamped V4/1/68. I assumed this to be a date stamp as the car was built late 1968 but not sure what the V indicates. I then noticed that the offside bracket is also stamped this time with V4/1/67.
It seems odd that one is 68 and one 67 unless whoever stamped the brackets picked up the wrong stamp, a 7 instead of an 8. or could it be that the brackets are stamped individually and then just picked out of a box and brazed to the crosshead.
Anyone else seen these stamps and are they a manufacturing date?
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
If I remember rightly the bracket you describe is either a casting or forging so it could be the manufacturing date.
Martin (Deano)
My 1950 Auster has quite a few parts stamped 1949. And each part has its own stamp and manufacturing date so Morgan, being of the same era and ilk, is likely to follow the same procedure. Just a guess.
1968 4/4 1600
1950 Auster J5B
Kitfox S5 Outback
Jodel D9
1988 Peugeot 205 GTI 1.9
deano #319850 17/11/15 11:06 PM
Think it's a casting, same as the lugs on a two or three speeder three wheelers chassis.
deano #319852 17/11/15 11:49 PM
E
E
Yes bracket was the wrong terminology, it is either a casting or forging.
Land Rover Series
Defender 90 SW
They are part numbers.
My car, built in early 65, has the same numbers.
Sorry for the poor picture quality, but you should get the idea...
crosshead_part_number
crosshead_part_number2
musew #321010 22/11/15 07:36 PM
E
E
Great, thanks for that, it clears up a small mystery. smile
Land Rover Series
Defender 90 SW
