7 members (Doug J, Dek, MJF, TBM, Guern, Ian Wegg, Bunny), 210 guests, and 79 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
Drive on the Wild Side
Originally Posted By DaveW
No substitute for three ears, and one more place to hit.......
10 points off for loosing originalitity laugh2 they do look good though
Adrian
I prefer the cleaner look of the "hex" ones.
+1 thumbs
or maybe you should go for the one eared spinners (like Bodicea).....
Giles. Mogless in Paris.
Could have done with them several times on the M5 this week Giles! scared
Two eared with a plain finish!
tom+4 Offline OP
2 eared spinner arrived yesterday 👍 and installed them today
But when installing noticed a bit of play on front richt wheel bearing
So question ?
Can you adjust this or need for changing?
Play in bearing is in and out not up or down or sideways difficult to ew plail
Gr tom
You could check the tightness of the castellated nut (remove split pin first) but don't over tighten.
tom+4 Offline OP
What do i need to remove to reach the castelhaed nut ?and witch tools do i need to finish the job
Gr tom
Long nosed pillars to remove the split pin - rotate the hub until a small hole in the hub aligns. You may need to remove some grease to fin the hole. Socket over the nut and see if you can tighten it - DO NOT OVER TIGHTEN as you will make it harder for the bearings, they then may seize and fail.
Then refit the split pin (ideally with a new one). This is the hardest (most fiddly) part.
I'd remove the brake caliper and disc and have a look at the condition of the outer bearing while you're at it.
1972 4/4 2 Seater
