1 members (david nathan),
285
41
New
Topics48,365
Posts813,354
Members9,215
Posts: 1,363 Likes: 11
Posts: 1,363 Likes: 11 |
Exact same symptoms when I stopped for gas. Starter would not turn fly wheel. Compensator failure.
Posts: 286 |
Exact same symptoms when I stopped for gas. Starter would not turn fly wheel. Compensator failure. Great.....:/ What did you do?
Trailered it to dealer. He ordered the Centa unit. During the process it was discovered that the original compensator damaged the main crankshaft so the S&S went back for a rebuild. I picked the car up yesterday after almost three months, many dollars and missed drives.
Posts: 286 |
Stuff like that makes me think this might not be the toy for me...
Mine is a 2012 build. Everything that was recall worthy has been fixed or replaced. The newer models should not have these issues. Do not despair. Leave that to the pros.
Posts: 2,356 Likes: 2
Posts: 2,356 Likes: 2 |
I dismantle the starter The selunoid run but not the starter My centa unit is new...
 New Varta
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
So are all your starter problems gone after fitting a new battery? What is the part number please. Is it a straight swap with no modifications required to fit?
Posts: 1,562 |
Hope your starter problems are solved. Any hints /tips fitting the aero screens ?
Only the Check engine light again
