1 members (tommog),
176
80
Topics49,849
Posts837,425
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Exact same symptoms when I stopped for gas. Starter would not turn fly wheel. Compensator failure.
Posts: 286 |
Exact same symptoms when I stopped for gas. Starter would not turn fly wheel. Compensator failure. Great.....:/ What did you do?
Trailered it to dealer. He ordered the Centa unit. During the process it was discovered that the original compensator damaged the main crankshaft so the S&S went back for a rebuild. I picked the car up yesterday after almost three months, many dollars and missed drives.
Posts: 286 |
Stuff like that makes me think this might not be the toy for me...
Mine is a 2012 build. Everything that was recall worthy has been fixed or replaced. The newer models should not have these issues. Do not despair. Leave that to the pros.
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
I dismantle the starter The selunoid run but not the starter My centa unit is new...
 New Varta
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
So are all your starter problems gone after fitting a new battery? What is the part number please. Is it a straight swap with no modifications required to fit?
Posts: 1,562 |
Hope your starter problems are solved. Any hints /tips fitting the aero screens ?
Only the Check engine light again
