Old Book
Topics49,940
Posts838,604
Posts: 1,075 |
Great work JV!
Did you figure out what type (brand/make) of clutch they use?
Dan
Posts: 462 |
So far we have found no manufacturer's name or any numbers expect for the Morgan part number that is on the outside of the box the clutch assembly came in. The only clue we have found so far came in the Centra compensator kit. The new pilot shaft bearing is a Ford of Europe product BEARING NADELLAGER 82ET 7600 DA 1 596 468
Will post pictures soon
JV Sclafani Boca Raton, FL '13 M3W Metallic Orange Pearl 128CI Steered by Empire - Riding on Ohlins
Posts: 462 |
[img:center] http://postimg.org/image/kfvf7eikv/[/img] Harley Davidson Original compensating sprocket diagram
Posts: 462 |
anyone that wanted to see how to assemble and install a new upgraded Centa compensator onto the S&S motor please check out this post called.......
Install a new Centa Compensator unit
Posts: 1,671 |
Just driven my M3W home from the Morgan factories Aero-Racing department having had chassis change and new Centa compensator - Wow what a difference.
The car is a totally different experience & I love it.
Where are the rattles!
Posts: 462 |
Agreed, the Centa rubber insulated compensator is much smoother and quieter than the original Harley Davidison compensating sprocket which has more of a mechanical sound. (Two compresses metal forks in cased in grease used to release the big piston torque) cheers to a smoother drivetrain 😎
Now for a very stable ride add the Ohlin's shocks which really do make a great difference in the riding experience! Happy motoring
Posts: 3,740 Likes: 82
Posts: 3,740 Likes: 82 |
Where are the rattles! Great to hear your back OK. Don't worry about the missing rattles - a new batch will be along shortly
Red Leader
Posts: 1,671 |
Where are the rattles! Great to hear your back OK. Don't worry about the missing rattles - a new batch will be along shortly Cheers mate - Didn't get to see yours yesterday - I take it it's made it home?
Posts: 1,213 |
Pleased to hear you're back on the road Mark :-)
Hugh
Posts: 797 |
Hey Mark Did you get a new clutch fitted? If so does it feel any different
