8 members (ScotiaSteve, Pittsartist, asbojohn, hugo, Clipper, DaveW, RedThree, Ncik P),
200
54
Topics49,859
Posts837,507
Posts: 22,360 Likes: 353
Posts: 22,360 Likes: 353 |
2005 is one speed. 2012 is nine speeds. Off-slow-fast-off-slow-fast-off-slow-fast.
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
2005 is one speed. 2012 is nine speeds. Off-slow-fast-off-slow-fast-off-slow-fast. uups....: I mixed up the fan speed with temperature steps.. (my fan has 3 steps: off-slow-fast)
Posts: 27,811 Likes: 749
Posts: 27,811 Likes: 749 |
Try reaching behind the dash. The switches have locking nut at the back. Try to see if it is loose.
My 2006 car has 2 speeds. The switch is illuminated with all the others but lights up more when I push it in
Posts: 1,703 Likes: 35
Posts: 1,703 Likes: 35 |
That’s interesting John do you have the lollipop switches?
Roger 2011 Plus 4
No pushbutton ones into the PCB as per the photo on this post
Mine look the same but only one speed (and my nuts are tight). Gutted, poverty model obviously
Roger 2011 Plus 4
Strange Allon White told me it would have only one speed but it has two
It looks like it changed in 05/06.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
My 2002 Plus8 has a 2-speed fan with two position rocker switch.
Posts: 94 |
So? Some 2005 and 2006 car has 1 speed. The switch isn't' illuminated with all the others but light up when pushed in. Some 2006 car has 2 speeds. The switch is illuminated with all the others but lights up more when pushed in. There are may be a production fault on the PCB or a wire poblem or? Does anyone have wire diagram for these two models?
----------- 2005 4/4.
