5 members (gomog, +8Rich, sewin, Ricosan, CJB), 236 guests, and 82 robots.
+8Rich 75
Topics49,868
Posts837,651
Moggo
Page 5 of 5 1 2 3 4 5
Hoggy #323275 02/12/15 07:31 PM
Hoggy Offline OP
Thanks Jay, not sure I fully understand your advice but I will try to work it out.
I do get a little water ingress from the side window flaps but think this is not that unusual
Keith
Keith
2010 +4 Royal Ivory
Hoggy #323390 03/12/15 07:50 AM
I wouldn't worry about a bit of rain , its all part of the fun , my previous silly car was a 7 with no roof or screen ! A huge amount of fun still !
Hoggy #323393 03/12/15 08:07 AM
The slight slope on your header rail might be down to a distorted gasket....it's worth checking as you fit it down onto the top of the screen. The fasteners are adjustable as well.
You can get a bit of water coming in at the top of the screen supports. Many of us fit a bit of shaped neoprene there...a DaveW fix! Water can also come up past the side screen support brackets....usually road spray. That's fixable with a touch of neoprene as well....or a more expensive option, inner screen trims from the likes of Allon White or Williams.
Jays #323510 03/12/15 06:21 PM
Hoggy Offline OP
Thanks Jay, certainly would have needed neoprene today, hope the promised sun does arrive tomorrow.
Keith
Keith
2010 +4 Royal Ivory
Paul F #323582 04/12/15 07:17 AM
Welcome Hoggy from sunny Italy.
Originally Posted By Paul F
1) Inspect coolant hoses for any rubbing points against fixed parts of the car - bottom hose susceptible on a +4 IIRC - someone with a +4 will correct me on this.
2) Check the fit of the coolant header tank and make sure none of the pipes are trapped against the wiper motor.
....... Clip
Good luck.
1) The lower coolant hose can rub against a sharp edge of the engine castings. If that is the case loosen the clips just enough to move the hose and then re-tighten the clips. The sharp corner could be relieved with a little work with a file too.
2) Check that one of the hoses to the coolant header tank is not chaffing where it passes over the angle at the top of the foot well.
Hoggy Offline OP
Thanks for the nice welcome from sunny Italy, If you live in the Como region, with a Morgan, well done. Fantastic, what a stunning location to be.
I've recently discovered Talk Morgan and the welcome I've had has been a bit of a nice surprise. As far as Morgan ownership is concerned, it removes a lot of the potential isolation and is an exceptional resource. Great for the UK winter too!
I appreciate all the advice I've had and am about to print specific replies to serve as a check list. I did have a good look under the lid last night (with the sound of wind and rain testing the garage door) and can see the potential for radiator related problems mentioned. Naive question, but will my radiator be metal or something other. I think it is from last night's late examination but need better light! (2010 +4 and no service record of replacement)
Cheers
Keith
Keith
2010 +4 Royal Ivory
Hoggy #323638 04/12/15 12:42 PM
Hi Keith, your model is likely to be plastic. My 2011 +4 was plastic. As a precaution, I replaced my radiator 3 months ago with an aluminium one from Williams near Chipping Sodbury. The Williams rad is a very neat and well made piece of kit.
Ian
Hoggy #323756 04/12/15 10:13 PM
I did the same as Wirewheel last month too....as a precautionary matter on my 2009 Roadster. That was plastic and whilst not leaking, the lower hose stub was starting to distort and a leak would have been imminent.
The Williams ally radiator is a lovely piece of kit with well thought out mounts.
Jays #323983 05/12/15 06:30 PM
Hoggy Offline OP
Spot on with the distorted gasket, should be a quick fix I hope. One of the fasteners has the plastic stay missing, probably due to force in trying to combat the gasket twist. Talk Morgan is very effective. Thanks.
Keith
2010 +4 Royal Ivory
Hoggy #323997 05/12/15 06:53 PM
Hoggy Offline OP
I now get this completely Jay
Keith
2010 +4 Royal Ivory
