0 members (), 309 guests, and 37 robots.
Topics49,860
Posts837,486
Jonny72
Agree - when I fitted mine I made it so that it was about 2cm below the rear bodywork.
Neil
why not securely bolt a lightweight plastic trailer mudguard to the u/side of the rear Wheel enclosure.Simple&effective
When I fitted mine I used the existing Morgan Alloy Guards fitting bolts and holes - and the made a simple fitting for the rear screwed through the wooden subframe.
It worked a treat - for over two years and as far as I know is still working!
Neil
Ditto Nippy
bobo #324498 07/12/15 11:29 PM
Good idea bobo, I am also thinking on fitting a mugard on the top enclosure...maybe someone on this forum has already tried it and can tell us listening...
Its a job set for this winter.
Cheers,
Georges
Smaug,it works!mudguard needs trimming a bit.use big bolts&washers(X4)to join the 2 together securely & the 2 lift off as one, to expose a much cleaner rear Wheel area
There are several versions of fitting the rear plastic mudguard shown on TM. I think this is one of the best and well detailed Smaug. The only real difficulty with it may be using the lower shock absorber mounts for the support bracket, depending on which way the bolts are fitted it could mean removing the fuel tanks to get them out. There is not enough swing arm movement to get them below the tanks, at least with the NVH kit fitted. I have used the axle adjusting bolts to mount the support bracket and it seems to work.
http://www.talkmorgan.com/ubbthreads.php/topics/294278/Rear_wheel_Mudguard#Post294278
In deed, it is a nice work, looks good and solid to me....but I prefer a simplified way to be able to disassemble the hole thing quikly, even on the roadside by emergency. I think I will hold on bobo's idea (beside thanks for your reply, bobo) But first, let me get a mudguard and see how to do it stirpot
Cheers,
Georges
bobo #324865 09/12/15 01:01 PM
Do you have any camera
Red Leader drive
The rear mudguard that I installed ended up making more noise than I would have liked because of it being hard mounted to the body and when attempting to fix the issue I ended up cross threading a bolt, so i just removed it for the time being. When my 3 wheeler arrives back from the dealership I am going to install a modified version of the rear mudguard that doesn't require any additional mounting points. I will post new photos whenever I am done with the project.
Charlie, Former Editor
