7 members (Chris Cosher, Graham, G4FUJ, Morganmike, ScotiaSteve, TBM, SteveT, Simon),
312
85
Topics49,859
Posts837,481
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Posts: 2,539 |
I'm making a change to my "European model", ordered the slightly higher roll hoops (Aussie Spec) for my M3W. They'd be installed by now, but MMC sent me two equal roll hoops ... as in ... two roll hoops for the same side of the 3W, and none for the opposite side. That is an option I am considering, but how much taller are they??
Posts: 1,338 |
Why are you considering them? The standard m3w looks propositional all around..
Posts: 245 Likes: 5
Posts: 245 Likes: 5 |
About 240mm measured in the centre of the hoop (its on a slope!) Means the padding is in the middle of the back of your head which is much safer than the standard ones where the top of the hoop is level with the back of your head. Think about it if you get shunted the centre of the metal hoop in the back of your head - much safer the padding!
Posts: 2,539 |
Why are you considering them? The standard m3w looks propositional all around.. My thoughts are that if I go with the Fairburn carriages GT Aero screen then the taller hoops would look more proportional?
Posts: 1,338 |
Aha can you post the " fairburn carriages gt aero screen" first for me
Posts: 2,539 |
Aha can you post the " fairburn carriages gt aero screen" first for me http://www.fairbournecarriages.com/index...0&Itemid=65
Posts: 1,338 |
You are definitely on point, you will need the higher roll bars. Good luck
