Topics49,858
Posts837,464
Posts: 94 |
Have used it for years. It is a perfect tool for many small and large jobs in the garage. Has been helpful both on my motorcycles and cars. + many other things in the house. Considering now a rechargeable battery version 8200.
----------- 2005 4/4.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
As others have said - common sense applies, and limited use on cars, but a great tool. I've had mine out today to sand inside some holes in wood..............
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Always been on my list.....
Richard 1976 4/4 4 Seater
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
If you do go for a Dremel, get a genuine one, the cheap copies really are pretty poor in comparison.
As others have said - worth paying the extra $ for the real McCoy - a Dremel. I've had a rechargeable Dremel for a few years - they're solidly made and won't burn out. Proper bit of kit.
+8 4.8
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Had mine a few years now and find it very good. I use it mainly for polishing /grinding and sanding. Wire brush tools can also be handy to clean stuff too. My only criticism is that the slowest speed could be lower, but no problem so far. I have a storage case with mine and also bought a multi-compartment case to store accessories and bits bought over time.
Posts: 1,943 |
I use a dremel with a sandpaper disk to keep my toe nails trimmed. Works a treat.
Button
Button
Posts: 881 Likes: 31
Posts: 881 Likes: 31 |
Button Hi Bill,...Similarly, I use my Dremel knockoff to smooth-down my callouses! Hope you are staying dry and out of harm's way amidst the recent Pacific Northwest's wild and wet weather. Cheers, Bert
Bert & B1800 "Tis well enough to know how much to know; and when to know, not to know, too much."
Posts: 676 |
Button Hi Bill,...Similarly, I use my Dremel knockoff to smooth-down my callouses! Hope you are staying dry and out of harm's way amidst the recent Pacific Northwest's wild and wet weather. Cheers, Bert A true multi tool indeed, much safer than using the angle grinder
1989 911 Porsche Carrera Land Rover Series Defender 90 SW
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
A true multi tool indeed, much safer than using the angle grinder Bert Munroe's technique in The World's Fastest Indian!!
Bud 4/4 "Stanley"
