Topics49,837
Posts837,286
Posts: 92 |
Hello everyone, Iam trying to check my fuel pump pressure - can't find the schrader check valve - it doesn't seem to be near the injectors/cylinders. Is it located on the fuel filter?
Thanks again Andrew
M3W 986 3.2S Frogeye Midget 1275 BMW i3S Tesla Y New Ionic 5N BMW R12 Nine T BMW K1300S Jet 200
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
Standing in front of the rig facing it, the schrader valve is on top of the left injector (drivers side in the UK). It has a black plastic cover on it that unscrews. Hope this helps.
Posts: 92 |
Thanks rolsmith - I'll look again. When I looked earlier I did remove the plastic bung(on the drivers side - sort of similar position to where the throttle cable goes on the other side). Didn't see any valve there, just an open chamber. Do you have a picture? Thanks Andrew
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Hi there It would help if we knew what model Morgan and which engine you have, we could be a little more specific in our help for you.
For the Rover V8 engined +8s , the meter is plugged into a valve on the fuel rail at the back of the plenum chamber on the driver's side. The fuel line pressure that +8 is 40 psig.
Apologies , I have just realised this was posted in the M3W section so we know what the car is . My mistake. Sorry I don't know enough about this model to give you an informed answer.
