0 members (), 305 guests, and 72 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#328739 29/12/15 06:43 PM
SogMog flood defences
As an addendum to recent posts regarding the flooding to my village of Croston and the flooding of my house and Morgan, we have bolstered our defences with sandbags infront of the garage
Hopefully SogMog will not be repeated
The drive is sloping back to the garage with a soak away infront of the garage door so my son and I have been creative, thinking that we can divert the flow of any flood water with an arrowhead of sandbags
25 Comments
Awful... the whole thing is just devastating for everyone effected.
+8 4.8
I hope you are right and the water doesn't get anywhere near you , we are all hoping for the best outcome !
Fingers crossed for you Stewart....and for anyone else in the path of Frank!
Very neat and purposeful.
Good luck to all of you in the path of the next bout of high winds and rain.
Stewart, where does your ACO soak away to? Water may back up through this and thwart your cunning arrowhead design. So don't forget to put some bags inside your garage behind the door also.
Good luck.
Stuart
Hope all passes without incident.
Stewart, any airbricks or vents in your walls?
Worth blocking them as well to prevent water getting that route in.
Steward, whishing you luck when sitting out the next wave!
Some advise from The Netherlands (2/3 of our county has to be protected against flooding), behind the V shaped dyke of sandbags, I would put an extra one directly in front of the door. Golden rule: shorten the coastal line. You also create an additional line of defence. Finally, have pump ready so you can pump out water as soon as it comes in.
Good luck!
BertR
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
Best of luck Stewart.....and everyone else at risk.
I was pondering in my mind about the idea of getting the Morgan raised up on ramps/blocks, just in case the water gets through the sand bags.
Jaguar F-Type V6s roadster
2009 Harley Davidson XR1200
1986 Honda VFR750F (RC24)
Just thinking Stewart...do you have axle stands or some scaffoling planks (or similar) you could get the car up on? Might just save things.....
