3 members (Luddite, TBM, Image), 248 guests, and 80 robots.
+8Rich 77
Topics49,870
Posts837,670
Rudolf
Page 7 of 9 1 2 3 4 5 6 7 8 9
Originally Posted By deano
Yep photos please. It's a very interesting story.
+1
1560 #319426 15/11/15 06:26 PM
Come on, were all chomping at the bit.
+3 waiting
grin2
Brian
2014 Morgan SP1 (Rocket Red)
Originally Posted By Wirewheel
Originally Posted By PaulJ
I feared the worst Max, and it seems that you and your good lady had lady luck on your side that day. Your health is all that matters, cars can, and it seems, will, be replaced. Better buy that lottery ticket soon. Welcome to Talk Morgan, what a first post!
+1 a big welcome to you and Mrs Max
Welcome and what a first post indeed
This will go into the annals of TM history
Originally Posted By Spannerman
Hey MAX, I rebuit that car and its still going strong :-)
Welcome to this Forum, Spannerman, and congrats for the rebuild...so no chance to skip the fotos, curious to see the result sherlock...by the way from which country are you from? Would be nice to see more Luxemburgish M3W drivers on this Forum happy3
Cheers,
Georges
1560 #329734 02/01/16 08:22 PM
Phew Photos..
Whilst I´m able to rebody and reengineer a car I am not much of a computer nerd. can anyone help me on that?
For anyone interested:
I payed 16500,- € for the wreck
Frame and body repair added up to about 1500,-€ plus my work.
Then I reconstructed the front running gear using aircraft grade steel and rose joints, also a custom built steering rack, which is narrower and fits lower to reduce bump steer. I then installed 32mm motorcycle brake discs and Brembo calipers which turn out much lighter and more effective. Also they look much better behindt those wire wheels.
Turning my attention to the rear I reconstructed the swing arm and pivot points and installed a much smaller drum brake.
All in all I saved 10.5 Kilogamms unsprung weight at the back and 4.3 Kilogamms each side at the front, but then I dont use the mudguards.
Funny you dont get as wet in a MW3 when it rains
like you do in a Lotus S-Seven, which I also own.
In July 2014 the car was totaled again whilst standung in a parking lot. It was then I found out that the whole body collapses when its shunted up the rear. Morgen was again not able or willing to sell a complete body so I made a new one myself using 1mm gauge Aliminium instead of 1.5. I also made a new nosecone from the same meterial further reducing weight.
Really the story goes on and on including Bevel box touble, engine to gearbox coupling and so on.
Welcome to TM and an interesting story? Sounds like you could find a great job in Malvern for some company or other....
Roger
That's some history with your car Spannerman and what a project I wish you much luck and many happy miles.
Keep us up to date with your adventures I believe you are the first person to have rebuilt an M3W, well done.
Hi Spannerman
Re photos, I find easiest way is to use the "File Manager" option just below the box you type into for posts
You can then browse for and upload pix files ( max size 4 or 5 mn ?? I think )
1560 #329780 03/01/16 09:12 AM
Thanks for the tip on Foto-Upload, I´ll have a go.
