0 members (), 230 guests, and 23 robots.
+8Rich 93
John V6 49
Posts837,990
rockabilly john
#330713 06/01/16 11:52 PM
Colsmog Offline OP
When I tighten the screw which holds the rim on the n/s Headlamp,the rim jumps out of the retaining lugs at the top of the headlamp. Wont do this if I undo the screw a couple of turns
Rim does not look to lie flush all around against the glass of the headlamp,and I cannot see anything restricting it.
Headlamps are Wipac Quadoptics ! appear to be held in by screw and clamp plate the rear of the glass housing.
Think I may change headlamps.
Any suggestions !
Colin.
RX450 easier ezchair.
2004 Roadster.CM51ERS.
Check the back to back size and of the rim against the other side, you may find one is slightly larger than the other. Replace the badly fitting one or use packing at the screw to tighten the rim down against the retaining lug at the top.
Ian
Neoprene packing works well.
Post number 8888!
Colsmog Offline OP
I'll try a tap washer,and pretend its Neoprene.. thanks
See you at The Cottage in the Woods. Dave
Colin.
Post number 8888!
And post 8887, 8886, 8885, 8884, 8883, 8882, 8881, 8880, ..................................1
Post number 8888!
Auspicious
OK Colin - others may also wash up there on Friday night. thumbs
