7 members (Burgundymog, Stevo666, John Winn, +8Rich, verysideways, Tony Quinn, TBM),
281
46
Posts837,994
Posts: 82 Likes: 3
Posts: 82 Likes: 3 |
When I tighten the screw which holds the rim on the n/s Headlamp,the rim jumps out of the retaining lugs at the top of the headlamp. Wont do this if I undo the screw a couple of turns
Rim does not look to lie flush all around against the glass of the headlamp,and I cannot see anything restricting it.
Headlamps are Wipac Quadoptics ! appear to be held in by screw and clamp plate the rear of the glass housing.
Think I may change headlamps.
Any suggestions !
Colin. --------------
RX450 easier ezchair. 2004 Roadster.CM51ERS.
Posts: 3,643 |
Check the back to back size and of the rim against the other side, you may find one is slightly larger than the other. Replace the badly fitting one or use packing at the screw to tighten the rim down against the retaining lug at the top.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Neoprene packing works well.
Post number 8888!
Posts: 82 Likes: 3
I'll try a tap washer,and pretend its Neoprene.. thanks
See you at The Cottage in the Woods. Dave
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Post number 8888! And post 8887, 8886, 8885, 8884, 8883, 8882, 8881, 8880, ..................................1
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Post number 8888! Auspicious
Richard 1976 4/4 4 Seater
OK Colin - others may also wash up there on Friday night.
