3 members (RichardV6, bmgermany, Mick Annick), 217 guests, and 32 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,124
#331015 08/01/16 08:10 AM
Close to 3 years ago we (bought) and moved into my (now) wife's grandparents house. They had moved out in the late 80s and had rented the property. In that time the tenant had made a number of changes including carpeting over the original 1958 parquet flooring.
Last month (well actually up to and including 2nd Jan) was set aside for the renovation project. My hope was to renovate both the dining room and then living room and return the floor to its former glory. In early December the carpet came up in the dining room and a small area sanded back to check whether it was doable.
The answer was "Yes" - but the workload was likely to be extensive - and so with a long Christmas break ahead I started off. The process - for both rooms:
1) Lift carpet - which was glued down across the whole floor
2) Remove the foam backing and as much glue as possible with the Multitool
3) Using a sanding head on an angle grinder sand using 40grit the entire floor to remove the remaining foam, glue and original varnish.
4) Sand the floor using an orbital sander using 40, then 80 and finally 180 grit
5) Thoroughly clean the room removing all dust
6) Apply a coat of water based diamond finish varnish, allow to dry (2hrs), wire wool, 2nd coat, wire wool, 3rd coat
Then for the living room the whole room was painted and new skirting fitted.
In total the work took 9 days (72hrs) to do around 50m2. It was a beast of a job and there were a number of moments when I questioned why the hell I was doing it. Using hand (power) tools allowed me the control to remove the very minimum from the floor - but it did mean the job tool longer. I went through around 120 125mm 40grit sanding sheets for the angle grinder, 30 150mm 40 grit, 20 80grit and 20 180grit for the orbital. 7.5l of varnish. 2 face masks and god knows how many showers!!!
The worst moment was realizing that they had applied leveling compound on top of the parquet near the fireplace - and even now the surround will need additional work to make good.
The dining room will be knocked into the kitchen in a few months and the final picture shows the latest image sent from the kitchen designer.
2010 Aero Supersport | 2017 VW Multivan | 1996 BMW M3 Evo
Great job - you have created a real feature for the house. Parquet looks very contemporary when it doesn't have a dark stain.
last year I had about 200 sqm of oak boards restored and the guy used a german-made upright belt sander which was of a design unchanged since the 1950s. You are brave using only hand tools.
Stuart
That's an epic job but you won't half appreciate it everytime you look at it. I could well imagine you questioning why you started it when doing it!
Roger
Brave - but I felt I had no choice. I just didn't want to trash the floor by over sanding with a big belt sander. On a design like ours I'd have to sand on the diagonal and there was no guarantee it wouldn't have torn up chunks of the floor. Replacement costs would have been massive over here so throwing my labour at it seemed wise. I estimate we saved around 10,000chf in me doing the work - or 1,100chf (after tax) per day laugh
I used a Fein multi-tool and Metabo grinder and sander - the former stared to leak grease from the head when I used the diamond head when I was working on the leveling compound - but opening it up revealed no gear damage. Going out and buying professional quality kit was a wise investment.
While I was in the UK over Christmas I popped into the Algerian Coffee Shop on the Old Compton Road - they have a really old Swiss made coffee grinder!
@Roger - I rollered on the varnish (satin finish) and it makes the floor so tactile smile. Although the house is now colder frown
Drive on the Wild Side
What a super job you've done, and rightly proud you should be, I presume you have submitted the invoice to swmbo for labour and materials for future redemption on Morgan upgrades. grin2
Adrian
The 3D visual looks great and looks like it will be all worth it
Really nice floor now , looks a nice spacious house !
Posting Desperado
Posting Desperado
Looks very nice when are you coming over to help me out , plenty of coffee and biscuits . Spent y/day a/noon pointing around stone work on a feature wall with a tiny filling knife just so I could live with it. crazy3
What a wonderful job you have done. It looks superb.
BR Colin
Here are couple more of the finished surface.
Going forward it should only need a wire wool and revarnish (of exposed areas) every 10 years smile
