7 members (SailingTom2, Rainer Duell, JohnHarris, Sir Percival, RichardV6, Mark+4, sospan), 295 guests, and 26 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,028
Page 4 of 5 1 2 3 4 5
rolsmith #330939 07/01/16 10:07 PM
NVH or BB Retro Fit
BB Retrofit Kit
kirkusblog.com
1952 Ford 8N
rolsmith #331624 11/01/16 02:00 PM
Originally Posted By rolsmith
If you are short, you can look through the stock screen, if you are tall, you can look over the stock screen.
It will be interesting to see if anyone with a Fairbourne screen in the UK fails an MoT test, come the time. Construction & Use regs require that a screen through which the driver has to look needs both a wiper and a demister. We can get away with the fly screens (despite often looking through those myself when it's wet), as it's always possible to look over them. Not so sure about the FC screens in that regard however, particularly for short-ar5es like me smile
But as usual, it's probably down to the MoT tester at the time.....
In the US the screens must have DOT engravings. MMC isn't doing that. Also the tires and headlights must have DOT markings. Again, MMC isn't complying. It's why Maryland inspected and failed the car.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
So then what do you do? Take the flyscreens off, and install Blockleys or Excelsiors? if even those have the proper DOT markings.
kirkusblog.com
1952 Ford 8N
It's not about yearly inspections, or even inspections upon sale, only in trying to get Maryland to accept the cars. Mt dealer is readying a car for another inspection that will hopefully comply with Federal regs (you'd think MMC would do that for the USA market). Once MD approves, each car would not have to be inspected. My car is shipping right now with tires, headlights and windscreens that are not USA compliant. Like I said, you'd think MMC would be shipping cars that meet the regs under which they were approved, but nah...
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Im sure part of it is the fact that ever state is different. You must have the first car in MD?
kirkusblog.com
1952 Ford 8N
whow!! just had a look at that nvh kit! Mind boggling! So thats how Morgan got aroung the belt jumping after mounting the BB on Rubbers.
Draggin #332496 14/01/16 04:19 PM
Not the first one at all. The others have flown under the radar. It's US regs, not each individual state, that require DOT compliance. Obviously Morgan got the car approved with DOT based on compliance that just isn't being met. It's not up to DOT to make sure the cars continue to meet the specs required. That's up to the manufacturer. Now... if DOT becomes aware... Kinda like of Chevy stopped installing seat belts; there's no DOT inspector at GM making sure.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
By the way, getting air into the tunnel to cool the BB is easyley acchieved if you take the first two screws out of the bottom tunnel cover and bend it down a little. I suppose you could use a couple of longer screws and a spacer if you want to secure the cover.
Adds an ounce or 3 of weight...
kirkusblog.com
1952 Ford 8N
