Topics49,851
Posts837,443
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I’ve just got around to fitting my Fairbourne screen (after it’s sat on my garage shelf for over a year  !) It's not too tricky to fit as long as you aren’t in a rush and can afford to take it steady. As others have mentioned, there is a risk of damaging the paint around the screen slots when trial-fitting the new screens. I covered the area around the slots with masking tape as a precaution.  Also, if I was doing the job again I would grind off the sharp edges/corners along the lower edges of the new screens so as to further protect against paint damage. When the new screens are trial-fitted you need to mark where to drill the 8 mounting holes but space around that area is very limited so it’s a bit tricky! I found that a sharp 1.5mm drill bit was an ideal scribe for this job.   Final tip: The tiny wood screws that hold the drip guard in place are also very fiddly so I replaced them with more 'normal' (Pozi 2) headed self tapping screws. The weather hasn't played ball so I haven't driven with the new screen yet. However when sitting in the car I was pleased to find that I can easily look around the screen if ever I need to. I haven't applied fresh silicone around the slots as mine is strictly a dry weather car and if I am caught out in the rain then hopefully the drip guard will do it's job. This decision will be reviewed depending on how wet my knees get!
Andy
Posts: 579 Likes: 5
Posts: 579 Likes: 5 |
in love with life. that's it.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 2,539 |
I am so anal retentive, that I probaby would have traced them out on a peeice of paper before installing them, should I ever need a replacement cut. But that's just how I am wired...
Posts: 1,947 |
I haven't applied fresh silicone around the slots as mine is strictly a dry weather car and if I am caught out in the rain then hopefully the drip guard will do it's job. This decision will be reviewed depending on how wet my knees get! Hmm, speaking as a two speeder rain magnet owner, chance would be fine thing in the UK. I've got very wet at Prescot, returning from BDC Silverstone and lots more events. I even churned up the grass and turned it to mud at the local parish show with what must have been a 150 yard wheelspin.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
I even churned up the grass and turned it to mud at the local parish show with what must have been a 150 yard wheelspin. Hooligan
Red Leader
Posts: 1,562 |
Hmm, speaking as a two speeder rain magnet owner I even churned up the grass and turned it to mud at the local parish show with what must have been a 150 yard wheelspin. You are just showing off now Martyn. Next you will be saying you did a couple of doughnuts followed by a 90 degree drift past the vicar
The finished article:   It was cold and bright earlier today so I managed a quick spin around the local lanes. I was just wearing a fleece, with no headgear and I survived without frostbite.  A definite improvement!
Andy
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Very smart job..
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Nice job. I have found the Fairbourne screen a big improvement and it keeps you fairly dry when its raining, at least when you are moving. I know you say your car is for dry weather but that will never work in the UK. When you do silicone the screens, I suggest a small bit of closed cell foam to plug the gap where the central support is to stop the stream of water that leaks in and then ends up on you.
