6 members (Burgundymog, uvk33n, Ritchie B, BLUE+4, Barry M, Deejay), 376 guests, and 67 robots.
+8Rich 86
Sagging Hood
Topics49,852
Posts837,446
Page 2 of 6 1 2 3 4 5 6
I’ve just got around to fitting my Fairbourne screen (after it’s sat on my garage shelf for over a year ooo !) It's not too tricky to fit as long as you aren’t in a rush and can afford to take it steady.
As others have mentioned, there is a risk of damaging the paint around the screen slots when trial-fitting the new screens. I covered the area around the slots with masking tape as a precaution.
Also, if I was doing the job again I would grind off the sharp edges/corners along the lower edges of the new screens so as to further protect against paint damage.
When the new screens are trial-fitted you need to mark where to drill the 8 mounting holes but space around that area is very limited so it’s a bit tricky! I found that a sharp 1.5mm drill bit was an ideal scribe for this job.
Final tip: The tiny wood screws that hold the drip guard in place are also very fiddly so I replaced them with more 'normal' (Pozi 2) headed self tapping screws.
The weather hasn't played ball so I haven't driven with the new screen yet. However when sitting in the car I was pleased to find that I can easily look around the screen if ever I need to.
I haven't applied fresh silicone around the slots as mine is strictly a dry weather car and if I am caught out in the rain then hopefully the drip guard will do it's job. This decision will be reviewed depending on how wet my knees get!
Andy
fantastic!
in love with life. that's it.
Looking smart.
I am so anal retentive, that I probaby would have traced them out on a peeice of paper before installing them, should I ever need a replacement cut. But that's just how I am wired...
kirkusblog.com
1952 Ford 8N
Hmm, speaking as a two speeder rain magnet owner, chance would be fine thing in the UK. I've got very wet at Prescot, returning from BDC Silverstone and lots more events. I even churned up the grass and turned it to mud at the local parish show with what must have been a 150 yard wheelspin.
Hooligan laugh2
Red Leader drive
Hmm, speaking as a two speeder rain magnet owner I even churned up the grass and turned it to mud at the local parish show with what must have been a 150 yard wheelspin.
You are just showing off now Martyn.
Next you will be saying you did a couple of doughnuts followed by a 90 degree drift past the vicar smile
The finished article:
It was cold and bright earlier today so I managed a quick spin around the local lanes. I was just wearing a fleece, with no headgear and I survived without frostbite. laugh2 A definite improvement!
Andy
SBM Offline
Very smart job..
thumbs
Nice job. I have found the Fairbourne screen a big improvement and it keeps you fairly dry when its raining, at least when you are moving. I know you say your car is for dry weather but that will never work in the UK. When you do silicone the screens, I suggest a small bit of closed cell foam to plug the gap where the central support is to stop the stream of water that leaks in and then ends up on you.
