0 members (),
284
59
Topics49,844
Posts837,360
Posts: 2,361 |
Floor mop & Flash..?? Its all looking alot cleaner now
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 2,361 |
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
That looks to be the maximum size rad you could fit. Nice work.
Martin (Deano)
Posts: 2,361 |
That looks to be the maximum size rad you could fit. Nice work. Thank you It sure is a work of art, as stated by a few people on here already using our road going version.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
A neat looking rad. I like the top mounting system. The bracket is welded to the rad frame? My Plus8 has it welded direct to the top tank, and started to peel away due to poor fitting and alignment causing stress to pull against the weld. Luckily no damage to the rad tank! Phew! A repair done using a second steadying bracket fitted with neoprene padding to kill vibrations.
Posts: 2,361 |
A neat looking rad. I like the top mounting system. The bracket is welded to the rad frame? My Plus8 has it welded direct to the top tank, and started to peel away due to poor fitting and alignment causing stress to pull against the weld. Luckily no damage to the rad tank! Phew! A repair done using a second steadying bracket fitted with neoprene padding to kill vibrations. No welding required, just bolts into place
Good design. Separate bracket to fit the rad, removing the danger of weld failure due to vibration.
Posts: 2,361 |
Good design. Separate bracket to fit the rad, removing the danger of weld failure due to vibration. Its proving to work very well. Well the car is moving aong nicely, just hoping Frankie delivers again this season (no pressure) !!!
Will there be a book? Title could be... "Frankie Da Story" Inspired by another winner.... Frankie Detorri....
Posts: 2,361 |
Will there be a book? Title could be... "Frankie Da Story" Inspired by another winner.... Frankie Detorri.... I very much doubt there would be a market for a book on this Frankie,who knows??
