1 members (+8Rich),
328
Topics49,897
Posts838,018
Posts: 26 |
Happy New Year from Australia during a hot summer. I have a 1982 plus 8, and even when it is only 25 degrees, the interior is a bit warm. My wife spent two hours with her feet on the seat last week! Does anyone have a good way of getting cooler air around my feet?
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
Take your socks off
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
Happy New Year from Australia during a hot summer. I have a 1982 plus 8, and even when it is only 25 degrees, the interior is a bit warm. My wife spent two hours with her feet on the seat last week! Does anyone have a good way of getting cooler air around my feet? I fitted ducting that runs from the front of the car (either side of the rad but just in front and behind the grill)with in-line electric fans. To be honest it doesn't cure the hot feet scenario completely but I couldn't work out how to fit air con
Steve L.
1996 Plus 8 N22 MOG
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I think it's a bit mean to talk of it being too hot when the UK is so bitterly cold.
+8 4.8
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Bonnet catch extenders to allow some of the underbonnet heat build up to escape. Looks slightly odd when you are not familiar with theie use. Always confuses at least one marshal at out local hill climb as they assume the bonnets are not fastened down...
Posts: 3,564 Likes: 13
Posts: 3,564 Likes: 13 |
It would help the heat build up hugely if you wrapped your primary pipes, other than that, as others have said, experiment with ducting in fresh air from the front, and stick heating reflecting insulation on the engine side of the bulkheads, which is a really fiddly job, even with the engine out, or put more insulation in under all the footwell carpets, not forgetting under the bulkhead. Anything to prevent the heat soak from getting to the cabin.
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
The bulkhead can be insulated with Reflect - a - cool from Agriemach. It's self adhesive foil and although a bit fiddly to apply, works well. I did this to my Roadster. The transmission tunnel should already be insulated on the inside. I think most of the heat transfer is through the bulkhead so start with that.
Posts: 766 |
Tuftie66 2008 Claret Red +4 Sports 2016 Mazda CX-3, Sport AWD.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
And bring some of that heat with you
Red Leader
