5 members (jbk, Mogdavid, AndyGoff, rossocorsa, BertL), 223 guests, and 85 robots.
Topics49,847
Posts837,387
Page 8 of 34 1 2 6 7 8 9 10 33 34
Ken, do you think your car is overheating?
A different tack, and probably cheaper and easier than Waterless Coolant would be to add Water Wetter - quite common with V8 (Morgan and other marque) owners over the years. This would also mean, should you have a coolant leak, you can just add water/antifreeze. If it's not been done I'd recommend flushing the rad and block, before doing anything else... smile
Originally Posted By Ken A
orry guys my last note was addressed to Bobthe Train's msg at 08.15, since followed by positive words, thanks Bob
Using the quote facility will enable you to place your comments in the correct context
Ken A Offline OP
Tim
OK but this site is c**p at telling anyone how to use it. I can't find how to use "quote" facility
Ken
Ken A.
Plus 4 2009 Centenary Metallic Red
Plus 8 1994 Dark Green (prev)
Honda CB100 The Big One
Tim
Ken
Ken - hit the third button along below the message you want to reply to marked "quote".
Roger
Tim
Ken
Press the "Quote" button at the bottom ot the post.
Oops! Beaten to it.
Best Regards
Lang may yer lum reek
Tim
Ken
If you look at the box where the post you are replying to is displayed, you will see some buttons, one is marked 'Quote'. Click on that and the text is copied down into the reply panel, surrounded with the formatting tags to ensured it's displayed properly.
Instructions on how to use the forum are available under the 'Forum Help' link on the top menu.
Ken, for a relative newbie I don't think you have made a good start on here!
Upsetting the guys by making demands and being rude probably isn't the best way to seek help from what are a bunch of very experienced and friendly owners, at least I have always found them so. But then I don't insult them by calling them pillocks.
I doubt you'll get much help on here with that attitude, and I would think an apology is due.
The search option does indeed throw up a whole lot of good information. See the search box at the top left of the page.
"this means the end of the horse-drawn Zeppelin!" - N Seagoon
Ken A Offline OP
Tim
Ken
Check??
Ken A.
Ken A Offline OP
Tim, the word check is mine
Ken A
Ken A.
