4 members (Ulfulf, JohnMat, Soleng, Hamwich), 308 guests, and 51 robots.
John V6 68
+8Rich 65
DaveW 64
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,062
Captain Morgan, IRWIN
#336878 30/01/16 10:23 PM
Is the organ pedal mod' worthwhile? does it enable you to heal and toe? I was thinking of "nailing" something to the existing throttle operator in order to connect with the heal when required. Has anybody tried a DIY option? A nice elegant solution would be a good addition.
I fitted one about five years ago, a simple job. I don't use it for heal and toeing but it is much more comfortable than the "roller", especially on long drives as it allows you to move the pressure point on your foot around.
Steve L.
1996 Plus 8
N22 MOG
Some like them, others not.
On one trip to Scotland with a small group, an hour was spent removing one from a +8 one morning. Car had been fitted with one from new, but the owner could not get on with it, though I don't think he realised it was the pedal causing his problem. He was much happier driving afterwards. smile
Best to try a car with one fitted if you can... drive
'09 Gen2 MINI Cooper ragtop
jbk Offline
Removed mine also, i don't have particularly large feet but kept catching the brake pedal. I then refitted the roller to the outer (right hand) side and that made a great difference. As Graham says, Organ pedal not for everybody.
Fitting a slim foot rest above the clutch pedal is also worthwhile, saves your foot from hovering on long trips.
1993 T16 +4 Lancia Blue.
I have yet to move my roller to the other side - quite a common alteration smile
Green & Grown Up
Green & Grown Up
I have not heard of that one Graham. Thanks for the tip. I will take a look now. thumbs
However, I have always been quite happy with the Roller as is but then I dont Toe & Heel.
The Foot Rest over the Clutch Pedal sounds interesting also, so long as it doesn't get in the way of my size 9's .
P4SS had a roller and it hurt my foot when I had soft shoes on so fitted an organ pedal and found it much better, I will fit one to the ARP4 when it ever comes.
It also stopped the throttle bounce on rough roads at low speed.
My wife has very small feet and couldn't reach the roller so couldn't drive it mmmm forgot about that so may be will put up with the roller. redcard
Peter.
Aero plus8 50th Anniversary.
V
V
I couldn't get used to the organ pedal, and had Techniques replace it with one of their fabricated "conventional" pedals, which does away with the roller. Heeling and toeing is now easy!
vbalddave
Red 1993 +8 3.9
North Yorkshire
A few pictures from yesterday of the pedals .I noticed a roadster in the trim shop with different pedals altogether.
Peter.
