Topics48,354
Posts813,206
Members9,215
Posts: 1,213 |
Blimey just come across this and there's a lot of replies , I'll add one more !
My car ( Sept 12 ) was used through the first two winters regardless of weather and salt , it was just about possible to keep it looking OK , plenty of ACF50 certainly helps although it does seem to attract dirt . Certain areas certainly on the early cars had very poor paint , swinging arm and headlight supports being particularly bad . The aluminium bodywork survived very well , as did the interior despite being soaked on numerous occasions . When my replacement chassis was fitted it was much better finished and seems to have some sort of wax coating on it . Mine is for sale in Krazy Horse at the moment , so if you want to see a well used 15,300 mile example it'd be a good one to look at !
Hugh
Hugh
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
What are you replacing it with, Hugh..?
Posts: 1,213 |
Nothing at the moment Steve , since moving house and associated 'jobs' I have hardly used it and I dont think it does it any good sitting around . I'm also planning to knock the garage down shortly .
I won't rule out another Morgan some time in the future , but for the moment will have to make do with my Fiesta ST.....
Hugh
Hugh
Posts: 1,944 |
Hugh I hope you can cope with the withdrawal symptoms, perhaps you can go to a Morgan dealer & look through the window if it gets bad. Going in may be risky.
Tim
