11 members (MartinB60, Jon G4LJW, RichardV6, chanteclair, Detlev V6, Chris99, TalkMorgan, TeddyAds, Scrambledsignals, mph, DCH),
258
Topics49,910
Posts838,136
Posts: 990 |
I don't pretend to be an expert BUT that looks very bent and i think will need a new frame at the least i am afraid to say. The body tub looks twisted too - its a brave rebuild to be frank. Best wishes with it and i wish you all the luck in the world but i'd think very carefully before you buy lots of bits.
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 1,075 |
Welcome and sorry to see you baby all banged up like that.
Were you not insured? I cannot imagine something of this value that would not be insured. If it's financed, it has to be. Even paying cash, I would not go without collision on something like this. I had my last streetrod insured for $85k. I built it and could do anything on it, but man, I would not go anywhere without insurance.
In the US this would clearly be a total loss as the frame is clearly more than just tweaked a bit.
If it is insured, I agree with the others, the factory is the place to start. I know that several so far have had the upgraded main frames replaced due to the right front upper rail cracks. Even with metal experience, why do it if it's insured and you can get an upgraded frame out of it.
I've watched the How It's Built moving many times and the way they do the ash wood frame for the body work, splicing and cutting the wood to get the correct arch to the sides would be difficult at best. A new body is what I would look at doing.
I'm sure the guys here will steer you to the right places for parts.
Good luck with your repairs.
Dan
Posts: 2,781 Likes: 5
Posts: 2,781 Likes: 5 |
That's like a banana, unless you have all the right tools and knowledge I'd leave it to the professionals.. Probably lots of hidden issues there.
Steve 2008 4/4 1.8 Duratec
Posts: 582 |
Oh man Retro, my heart goes out to you. Looks like factory unless you have a good panel beater close, good luck
Posts: 9 |
That's like a banana, unless you have all the right tools and knowledge I'd leave it to the professionals.. Probably lots of hidden issues there. Haha "banana" .... No it look much more bend than it is, there is only 1 tube in rear frame that need replacement the other i need to stright up little, swing arms are 100% ok cross measures with laser from front spindle to 10cm from rear are 100% ok to.
M3W Super Dry 2013 (will be rebuild for own use) Hult Healey R3.5 V8 (replica) Ducati Monster 1000
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
The factory seems to be the best place for your rebuild. Frame is not a big problem for me. I have skills in road racing motorcycle frame building, problem can be aluminium work because it need many hour to be good. It's great to hear you have the confidence to work on the frame. That frame is bent in several angles, and worries me just looking at the photo..! I would guess you need to fabricate a jig with the correct geometry first, and then either align or replace tubes? I don't think for a minute that Morgan will supply you with parts of the tubular frame, mainly because it's not built by them. It's made to spec by a supplier and they buy a unit once complete. They will always replace rather than repair for litigation purposes and legality, as they have no jigs. This means that you'll be starting with a clean sheet of paper and finding tubing of identical properties alone. You may be well able to do this, and perform your magic on the frame. Is the finished car going to be used on the road? If so, I would expect some form of inspection and/or testing for insurance purposes. You would have to pay for this too, I'm sure..! That's just the frame. The body could be fabricated by an expert, or you could possibly purchase a new one from Morgan. You would have to ask about that with them. From a cost perspective, if you have sufficient skills and a certain amount of money it could be done. If your time is limitless, then you can be in pocket with the final costings. If however, you intend to sell the car onwards once repaired then please don't sell it to the UK - I've seen privately repaired vehicles before! I'm guessing you aren't a professional vintage car restorer, or you wouldn't be asking questions on here. Good luck!!
That's like a banana, unless you have all the right tools and knowledge I'd leave it to the professionals.. Probably lots of hidden issues there. Haha "banana" .... No it look much more bend than it is, there is only 1 tube in rear frame that need replacement the other i need to stright up little, swing arms are 100% ok cross measures with laser from front spindle to 10cm from rear are 100% ok to. Well if you sort that out correctly I take my hat off to you.. It looks bad to me. Wish you all the best with it though.
Posts: 9 |
I try to ask again.
Where is the best place to buy spare parts for a M3W in Europe?
I need following parts
Rear wheel (rim) Rear lights Fuel level sensor
Posts: 853 |
Please look at PM's. Look at the flashing flag on the tool bar at the head of the site page
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
I can help with fuel sender - 280mm one available here
