6 members (Jon G4LJW, DCH, RichardV6, BobtheTrain, Gordon D, Zach), 235 guests, and 69 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
Page 3 of 4 1 2 3 4
I wanted to provide some additional entertainment in my 2011 1.6 Sport and sddidd not want to modify the car. I liked your suggestion of using the Bose speaker system and purchased one myself. I must say I am somewhat suprised at the quality and volume that can be acheived with such a small speaker and I am a bit of a HiFi nerd.
In my case I have fixed the speaker to the transmission tunnel with Velcro which appears to work well well and allows it to be removed for security.
My audio source is my mobile phone which is linked via blue tooth or a cable if I wish to use the radio(with most phones with FM radio the FM won't work at the same time as the bluetooth). I have ordered a case/sleeve for the speaker which has red piping and should match the red dash
4/4 1.6 Sport
U
TM Photographer of 2008
U
Did you fit the Velcro to the rubber pad on the underside of the Soundlnk or take the pad off? Can you still use the cradle for charging or do you have to charge via the micro usb?
Ken
Super job Milt
Looks great
I've got a powered subwoofer under a false carpeted panel in the passenger footwell which makes a hell of a difference so I can listen clearly to my two favourite sounds at the same time
A Morgan sports exhaust and Ian Dury and The Blockheads
Reasons to be cheerful - part 3
I have stuck the velcro to the speaker. I was concerned about the speaker jumping out of the base unit. It is quite heavy and you would not want it flying loose. I have ordered a rubber protective sleeve for the speaker but I wanted one in red to match the dash but that colour is currently out of stock. Depending on how the sleeve fits I might fit the base unit and make a retaining strap for it
4/4 1.6 Sport
Milt Offline OP
Thanks. It fits well but could do with some finishing off so plan to have a small 5mm bead in matching leather around the speaker grill, when the car makes a visit to Williams later this spring for interior leather door trims (or whatever they are called). That way it will fit more securely and not fall though the aperture.
Steve. Yep, sound surprised me too, as did the build quality and battery life. It's a heavy lump.
J. Neil
Originally Posted By rainbowj
Originally Posted By twotribes
Originally Posted By Burgundymog
Warning to those of you who use an iPhone or other mobile device to search / control music while driving, you may not realise you could be committing an offence as "using a mobile phone OR OTHER mobile device" is an offence.
What's the difference between this and using a GPS navigation app on a mobile phone (in a cradle) - or is that technically an offence also?
Surely you should set your destination whilst stationary. Any subsequent action that distracts you from driving is an offence - like swigging from a can of coke.
Or a cup of coffee? hide
Steve L.
1996 Plus 8
N22 MOG
Looks like it was meant to be there !
Milt did you consider placing it in the radio aperture. My 2011 4/4 has one with a blanking plate.
Is it located next to the heating outlets?
I was wondering because the size indicates a radio but the location looks awkward to me.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Milt Offline OP
The picture is with the Bose Speaker inserted into the Radio aperture.
J. Neil
Page 3 of 4 1 2 3 4
