8 members (Moggo, John Winn, CooperMan, Morganmike, Pittsartist, Graham, G4FUJ, JoeSpeetjens, RobCol),
311
119
Topics49,869
Posts837,656
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Luckily for me my '76 came with 4.1 as standard
Richard 1976 4/4 4 Seater
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
Crown wheel and pinion is 1200 €, plus at least 800 € for the conversion. That's a lot of money. The question is, is worth the money? So far the price has kept me away from changing... I'm going for a ECU upgrade first.
Posts: 12,260 Likes: 319
Posts: 12,260 Likes: 319 |
Crown wheel and pinion is 1200 €, plus at least 800 € for the conversion. That's a lot of money. The question is, is worth the money? In theory, you don't need a new crown wheel, just a new pinion gear with one fewer teeth
Posts: 1,948 |
Crown wheel and pinion is 1200 €, plus at least 800 € for the conversion. That's a lot of money. The question is, is worth the money? In theory, you don't need a new crown wheel, just a new pinion gear with one fewer teeth For straight-cut gearsets, yes. But I thought helical gearsets had the pinion matched to the crownwheel and always needed changing in pairs otherwise the pitch/profile mismatch would cause the gears to eat themselves?
Stuart "There's no skill substitute like cubic inches."
For straight-cut gearsets, yes. But I thought helical gearsets had the pinion matched to the crownwheel and always needed changing in pairs otherwise the pitch/profile mismatch would cause the gears to eat themselves? GPWM
Posts: 486 |
Having driven Ice Packs 4/4 and mine back to back, our mogs were neck to neck on acceleration I only gained a nose as I could hold the gears longer. Ice Packs had the gear set change mine ECU remap on driving Ice Pack it felt flat and gutless but went like stink, mine felt like a bigger engine.
As a road mod I don't think I could live with it on long journeys as the rev's in 5th would be to high at motorway speed.
4.10 ratio 5 gear 2000 RPM 48.4 mph 2500 RPM 60.5 mph 3000 RPM 72.6 mph 3500 RPM 84.7 mph 4000 RPM 96.8 mph
3.73 ratio 5th gear 2500 RPM 66.5 mph 3000 RPM 79.8 mph 3500 RPM 93.1 mph 4000 RPM 106.4 mph
But as a B road Street racer it would be a blast.
The real answer for the road use is torque and BHP.
Cain
Wolf Cafe Racer 4/4 Sport
Posts: 265 |
How can I check the gear ratio that is on the rear axle? You can work it out using this tool: www.performanceprobe.com My handbook said 3.73 but I actually had a 3.91 final installed. e.g. Mazda ratios from: 1st 3.136 2nd 1.888 3rd 1.330 4th 1.00 5th 0.814 Put in your tyre sizes and change the ratios for the diff. Then compare with the MPH/KPH to RPM in your car.
Looking for another Morgan!
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Gulf44, thanks a lot, I must double check, but I'm rather sure that my 2014 4/4 also is equipped with a 3.9 rear axle comaparing the calculation with an acceleration video I have made.
As a road mod I don't think I could live with it on long journeys as the rev's in 5th would be to high at motorway speed. <snip> But as a B road Street racer it would be a blast.
The real answer for the road use is torque and BHP. I kind of agree, Cain, after 3 hours on a motorway at 80mph+ mine can be a bit wearing (although it's the wind blast that's more tiring that the revs) - but it's more than compensated for when you get off, and after all, who buys a Morgan to drive on motorways? They are just a necessary evil to be endured whilst getting to the fun bits...
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Tim, At that speed mine is turning over at 3000 rpm in fifth. Does that sound like 3.73?
