5 members (+8Rich, Morganmike, DaveW, TBM, Montegue), 173 guests, and 54 robots.
+8Rich 79
Luddite 50
Posts837,934
#345658 07/03/16 08:35 PM
bobo Offline OP
Rear nipple is just about possible with a narrower than standard greasegun'nozzle'.But the front nipple is inaccessible...ideas about how to grease this one?...apart from shaft removal!
You need a Sealey needle grease gun attachment. Look on EBay. I had just the same problem with the front uj on the prop shaft.
I do mine at the annual strip and clean with the transmition tunnel removed.
Drive on the Wild Side
Pop it down to your friendly local garage and ask them if they'd mind popping a great gun with stiff flexi extension on it. Mine does and it's worth the beer for the mechanic.
Adrian
It's worth being a little careful with a big grease gun on the propshaft bearings, they are needle rollers and a high pressure gun can easily damage the bearings. Unlike the stub axles, the needle rollers on the propshaft should have a very long life with very little lubrication.
Crikey - I have seen a grease nipple at the bevel box end of mine , but not at the gearbox end , I must have another look !
Is it like the BBox end one ?
( any chance you have a picture ( big ask I realise smile
Personally I'd leave it alone. If properly packed a U joints should last at least 50-60 thousand miles. As Hamwich said be careful. If you blow a sea lyour doing more harm than good
Lift out the two seat bases, four cap screws along the prop shaft tunnel and 4 at the back and left the tunnel cover off. Takes mins. The front one is a bit more of a bugger as you have to lift the transmission housing up, but again thats only 4 cap screws.
