1 members (Ian Wegg), 360 guests, and 47 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Mine is a 2016. There's a 2.33mm spacer in there to let the cover expel heat.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Been coming out the factory like that 4-5 months
See the slots in the front
Ahhhhhh...indeed
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Niiice!
kirkusblog.com
1952 Ford 8N
So Ken, yours is spaced AND vented?
Dolph
Saw three used M3W's outside Krazy Horse today. Early one had standard timing cover, no spacer. A second later model with spacing washers and a third with the JAP kit which does have three cooling slots. Had a good look at both models with standard covers and even felt along the horizontal ridges to see if there was a cooling slot but couldn't find one. Happy to be corrected though.
ZK-Mog
ZK-Mog
My June 2015 car has slots in the cover so it's been a while now
Will believe what you like but there is some of us that pay attention and go to the factory and leave the tour to hangout in the m3w shop ,crazy horse tried to sell me a new car which if I didn't no my stuff would have got 2013 car as new ?
So don't believe everything you see
ZK-Mog
ZK-Mog
June 15 is also when they went to the new exhaust mounts which you can spot easily because the mounting bolts are hard against the body as opposed to centred on the pipe.
And if you have the new cover Morgan did not have to take it off to do the cam pulley mod as it come done from s&s
