5 members (gaston, Paul F, mph, John V6, MartinB60), 332 guests, and 88 robots.
Topics49,846
Posts837,383
Page 2 of 5 1 2 3 4 5
John07 #347087 12/03/16 09:04 PM
Ken A......plugs will last a long time but best to remove and check them during annual services. If they look ok and gap is ok then just refit them. Remember...DO NOT overtighten them!
I do 7k+ miles a year and annual checks at service. I put new in 2 years ago so I had a starting point for life for my own satisfaction.
A warm engine will evaporate any water in the plug wells but a cover will prevent rain getting in on a cold engine.
To me your rusty plugs suggest previous owner may have stored the car cold in wet conditions with little mileage done.
Mine is garaged and I use a full storm cover when out and about that covers bonnet louvres. John Taylor Phoenix make. Excellent cover.
John07 #347088 12/03/16 09:08 PM
The other thing is as these extended life plugs will do very high mileages before needing replacement.. how many garages even take them out on routine servicing? This is a real problem with many Morgans doing such low mileages.. they stay in for years.
sospan #347090 12/03/16 09:12 PM
They are great covers, i have one. but Sospan , when you are out and about with your cover on, doesn't it get a bit tricky to see through the screen? laugh2
John07 #347093 12/03/16 09:16 PM
Ah....that's why people stare at me as I drive past......
John07 #347114 12/03/16 10:06 PM
I used one of these on the pre GDI Duratec:
http://www.sico-developments.co.uk/produ...iant=1007828036
It has to be trimmed slightly because of the Morgan water rail mountings and I also fitted it with a neoprene gasket.
It is something Morgan should provide, at least as an option, on all 4 cylinder models.
John07 #347119 12/03/16 10:48 PM
John07 Offline OP
SteveT,
Yes you are right about moving the plugs every year or so. I've not had my car a year yet and I know from other issues that it's been polished more than it's been maintained.
These new iridium plugs are said to have a long life.
Yes I was thinking about something on those lines. Not sure that I want to pay £200 though?
Cheers
Cheers
sospan #347121 12/03/16 10:56 PM
Ray Offline
But they don't see you. banghead
John07 #347169 13/03/16 08:32 AM
Not sure if it works for a Duratec but I nearly did this to my zetec powered 4/4
http://www.shropmog.co.uk/index.htm
John V6 #347597 14/03/16 02:24 PM
Unfortunately the Shropmog site uses frames and a link to the index (home page) is all you get if you copy the address.
It is an obsolete concept of web design and they really should transfer to something more user friendly.
John07 #347636 14/03/16 04:04 PM
Re. the SICO plug cover, I have 'mailed them but the reply was that it will not fit the GDI engine but thank you for the info.
Reg
