3 members (bmgermany, JohnHarris, sewin), 239 guests, and 33 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,038
#347442 14/03/16 01:09 AM
Marcus Offline OP
I am really feeling dumb. I am doing some touching up of the engine compartment and decided to replace the valve cover gasket and adjust the valves on my '70 4/4 Kent 1600 crossflow head. I cannot find the locking nut on the rocker arm adjusting screw. There is just a hollow threaded screw that goes onto the pushrod. What am I missing? I've adjusted valves on a lot of cars and there has always been some nut to secure the threaded adjuster in place. Is this threaded screw an interference type that requires a lot of force to move and then stays put. Seems unlikely but something must hold the screw in place. Any help would be appreciated.
Mark
1970 4/4 Morgan
Two '53 MG TD's
1949 MG TC
1988 Porsche Boxster
Marcus #347444 14/03/16 01:42 AM
On mine there is no locking nut. They are just tough to move!
Marcus #347467 14/03/16 07:30 AM
Yes, they are 'self locking' .. They stay put by magic. Just make sure you have a good fitting spanner and watch knuckles!
Marcus #347481 14/03/16 08:50 AM
Others above are totally correct, if you have a 'deep crank' ring spanner it will aid your work tremendously. As always 'Rule of 9' works but Ford at one time issued a TIB (Technical Information Bulletin) to say they should be adjusted TDC Firing on each cylinder in turn, to be honest and having used both methods there is no difference whatsoever whichever method you use and I have tried with the engine on a bench with a clock gauge on the crank and a DTI on the valves, as long as your on the back of the cam your fine.
BR Colin
Marcus #347485 14/03/16 09:09 AM
I'd forgotten about the Ford self locking valve adjustment!
DaveW #347500 14/03/16 09:41 AM
I've never understood how this is achieved, presumably it's something elegant, or is it just a case of having mismatched thread forms?
Marcus #347504 14/03/16 09:53 AM
It's a mystery to me. You'd think the heat cycle would quickly loosen them off.
DaveW #347507 14/03/16 09:59 AM
Indeed.
Marcus #347508 14/03/16 10:04 AM
Ray Offline
Works well, never had one work loose.
Marcus #347513 14/03/16 10:18 AM
Marcus Offline OP
Thanks for the input. I guess I was right but it seems a bit bizarre to say the least. I'll give it a go. Apparently it has been like that for 45 years so it must work. It is an odd or clever design. I like the belt and suspenders approach with the lock nut but I guess I have no choice.
Mark
Mark
1970 4/4 Morgan
Two '53 MG TD's
1949 MG TC
