Morgan Aero 8
5 members (JohnHarris, Saxman1964, gomog, Graham, G4FUJ, TalkMorgan), 260 guests, and 22 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,046
#34726 16/09/09 08:01 AM
afr Offline OP
Hello there,
I was pointed in "Talk Morgan" direction by the extremely helpful, friendly Brian (Aeroman) after I pestered him via PH for info about his Aeromax and it seems a great resource for owners. Thanks Brian! cheers
Really fallen in love with the Aeromax but being a few sheckles short of buying one right now, decided to buy an Aero 8 in the meantime - maybe become the longtime! Due to take delivery in couple of weeks, once some reg transfer paperwork completed.
In the meantime, have a couple of questions....
Is there a trickle-charger point built into the car? One of my cars has an attachment point under the dash, so extra easy to hook it up if not using the car for 2/3 weeks.
What are the service intervals? The Aero is an S3 #476 (Aug '07/ 1600miles).
Is there any model specific foibles I should look out for?
Thanks.
Alastair
afr #34731 16/09/09 11:39 AM
Mr Fezza
Mr Fezza
Hi and welcome!
Trickle charging is via the cigarette lighter point (in / under the dash on the passenger side).
And before someone else says it - this thread demands pictures!
Maxxed out!
le Asbo du Bling
le Asbo du Bling
Alastair,
Welcome.
I would check first to see if you need to trickle charge. I've not had any problems with mine in the 2 years I've owned the car. But others have so it maybe an issue with each car. Can you check with the previous owner?
Regarding servicing its recommended every 6000 miles or annually. At 1600 miles I doubt yours has even been warmed up. I've just sold mine and that was an on a 55 plate and had covered 35,000 miles, so you'll have some catching up to do. drive
As Mr Tony said we need camera
Slowly going green
afr Offline OP
Thanks for welcome and info.
Was worried about flat battery as it may be a few weeks between drives as Aero has to go into storage for little while, while new garage built. Maybe it doesn't have too many things to drain it down though, like a Tracker.
afr #34737 16/09/09 01:22 PM
afr Offline OP
Not 100% sure about the grey centred wheels yet and may change later.
afr #34739 16/09/09 01:27 PM
Thanks.
Alastair
Welcome to Talk morgan Alastair wine
I trickle charge mine - if left for more than 2-weeks starting it gets iffy. Much of this depends on whether you have an active tracker, passive tracker and how the radio is set up. Obviously these are all drains on the charge and therefore the longer you leave it the lower the battery charge will be.
Reference the service intervals, as Asbo pointed out, the manual states fairly regular servicing. Many have argued that the BMW engine is capable of going much longer without attention; however, the actual reason for the service is to also ensure that the overall structure of the car is still tight and as it should be. A lot of power, in a light car, that is predominantly aluminium, can wreak havoc and therefore all the screws, nuts and bolts are checked to ensure they are tight and nothing is coming loose. A hand built car requires more attention than a mass produced model.
As for "foibles", no. Fist owners usually resolve these, which is a benefit to the second caretaker!
If the previous owner hasn't driven the car in the rain, you may find the hood needs to be adjusted to ensure total weather proofing but I cannot think of anything else that would be a standard "look at this" item.
Congratulations on your new car. smile
Simon #34742 16/09/09 01:51 PM
afr Offline OP
Thanks Simon and congrats on great site. sunny
Servicing all sounds fine then, as I don't mind keeping on top of these things and my local dealer, RPM seem a great bunch of Morgan enthusiasts.
Should add that competing for my attentions while Aero hunting, was a lovely looking S1 (from pics at least) at Thomas & Potter (Scotland), in case anyone searching now also... http://www.morgansinscotland.co.uk/sales_picture4.htm
afr #34750 16/09/09 04:32 PM
Mr Fezza
Mr Fezza
Wow - 37k for a MK 1. They are hardening in price smile
Pics of your car are great - looks lovely.
As Simon, mine have in the past got iffy if left for mroe than a couple of weeks without driving. Not sure if the S4 is the same in that regard but, I just charge it regardless..
Maxxed out!
le Asbo du Bling
le Asbo du Bling
But look at the mileage done less than a 1000 miles a year. Seems a pity to have such a wonderful beast and not to have used it hide
PS Alastair the car looks great and I'm sure you'll enjoy every minute with it. wine
Slowly going green
afr #34757 16/09/09 09:17 PM
Green & Grown Up
Green & Grown Up
Welcome to the forum Alistair,
Beautiful Car - enjoy the experience. I cannot imagine leaving it laid up for so long - a car like that needs driving!!! The year is shortening so get to it. life can be allwork innocent
