2 members (sprinty, MOGDave),
296
Topics49,844
Posts837,360
Posts: 5,210 |
That's a bug*er! Sorry I couldn't get down to see you but just too busy today...
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
I thought at first the tyre had moved on the rim slightly , cutting the valve neck Strange, are you running a tubed tyre in the back? maybe as you say picked up some debris that physically ripped the valve apart.
Posts: 1,562 |
I am running the standard Yokohama , which I assume is tubeless ?
I am running the standard Yokohama , which I assume is tubeless ? It'a tubeless, ordinary, radial.
Posts: 797 |
My tyre does deform on cornering. No doubt about it. It fouls the belt on sharp left turns and slow speed.
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
Interesting problem that one, could the valve have been defective or not installed correctly?
Slowly going green
Posts: 1,562 |
Interesting problem that one, could the valve have been defective or not installed correctly? This did cross my mind , especially as the tyre is very new and has neglible miles on it but I dont have any way to prove what has happened. I dont think the evidence of a perfect tyre but with the valve hanging off will count for much. Pressure was 25PSI (i.e. stock pressure for the rear ) checked that morning. I think I will experiment with it good bit higher.
Posts: 902 |
What tyre pressure are you running?
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
The valve is pretty close to the drive belt - could it have snagged and been torn off?
Red Leader
Posts: 1,562 |
The valve is pretty close to the drive belt - could it have snagged and been torn off? I dont think its this, I thought the rear tyre is pretty rigid under corner unlike the front , but I will check the clearances.
