5 members (IcePack, CooperMan, mph, Morganmike, RedThree), 378 guests, and 41 robots.
+8Rich 92
Topics49,841
Posts837,310
Page 108 of 264 1 2 106 107 108 109 110 263 264
That's a bug*er! Sorry I couldn't get down to see you but just too busy today...
Roger
Originally Posted By nippymog
I thought at first the tyre had moved on the rim slightly , cutting the valve neck
Strange, are you running a tubed tyre in the back? maybe as you say picked up some debris that physically ripped the valve apart.
I am running the standard Yokohama , which I assume is tubeless ?
It'a tubeless, ordinary, radial.
My tyre does deform on cornering. No doubt about it. It fouls the belt on sharp left turns and slow speed.
le Asbo du Bling
le Asbo du Bling
Interesting problem that one, could the valve have been defective or not installed correctly?
Slowly going green
This did cross my mind , especially as the tyre is very new and has neglible miles on it but I dont have any way to prove what has happened. I dont think the evidence of a perfect tyre but with the valve hanging off will count for much.
Pressure was 25PSI (i.e. stock pressure for the rear ) checked that morning. I think I will experiment with it good bit higher.
What tyre pressure are you running?
The valve is pretty close to the drive belt - could it have snagged and been torn off?
Red Leader drive
I dont think its this, I thought the rear tyre is pretty rigid under corner unlike the front , but I will check the clearances.
