8 members (IcePack, MATTMOG, James B W, CooperMan, DMC1904, mph, DJC, Morganmike), 327 guests, and 38 robots.
+8Rich 64
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,339
Members9,215
Page 2 of 6 1 2 3 4 5 6
PaulJ #348691 18/03/16 07:51 AM
It does seem low doesn't it. The "normal" running temperature of the Duratec is, I believe, 92°. Once hot mine is always between 90° and 100°. I think that the fan goes to the faster speed at about 95° and clicks off when the temperature drops below 92° but this is just from memory, I would have to check that.
If the instrument lights that you have are LED they can not be dimmed with a simple rheostat. LED lights are dimmed by turning them on and off at a high frequency, by changing the frequency you can make them brighter or dimmer. The speed is such that the eye doesn't see the fact that the lights are, in reality, flickering but a video camera may show the flickering because of an interference in the frame rate and the LED rate.
To accomplish this trick you would need a special control box. Cars with dimmable LEDs would have such a control in one of the lighting control units.
PS. If they are not LED dash lights it could be the same as our car. In that case the dimmer is a small knob under the dash near the steering wheel.
PaulJ #348717 18/03/16 09:48 AM
SFO Offline OP
Originally Posted By PaulJ
One or two other things I have noticed is that the water temperature seems to run very cool at between 70 - 80 degrees, which seems very low to me, and has anyone found a dimmer for the instrument lights yet?
same here, except that in traffic, temperature goes to 93C
PaulJ #348724 18/03/16 10:12 AM
CBY Offline
It seems to be nominal:
cf page 27 of Cosworth information handbook:
http://www.atss.planet.ee/kolaladu/ford/Sierra-escort/cosworth_yd_information_handbook_1_0_(web).pdf
"Thermostat is a conventional manual device with a 82°deg set point. It is entirely normal for the thermostat to open at lower
temperatures whilst at high engine speed in order to maintain sufficient coolant flow through the engine."
An other remark, all the power charts have been done with a 70°C coolant inlet temperature.
Regards
2005 PLUS 4
SFO #348727 18/03/16 10:47 AM
70°C could be a little bit on the cooler side of regular for normal road use. I guess Cosworth will insure that the engine never goes too hot during a track day event.
SFO #348757 18/03/16 12:58 PM
Surely, Cosworth and Ford (the makers of the base engine) each have different prime goals? Fords will be economy, emissions, low engine wear and the ability to operate any where in the world. Cosworth's only goal is performance. These different goals require different operation conditions of things like water temperature.
Cheers
Gambalunga #348759 18/03/16 01:04 PM
Peter, there could be a difference between coolant inlet temperature and the point where the coolant sensor is mounted at your engine, there placed probably reading higher temperatures.
SFO #348762 18/03/16 01:12 PM
Gents, you are all assuming the factory gauges are accurate.....
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
SimonH #348763 18/03/16 01:15 PM
Simon @ SiFab.co.uk
my are surely not, Gauge reads 5C more than my OBD...and that will not warranty that the coolant sensor is also ok (which is in case of my 4/4 the same sensor for OBD and Gauge).
SFO #348764 18/03/16 01:17 PM
SFO Offline OP
there is a digital readout of water temperature in the display area of the speedometer, accessible by pressing the black button ..
the digital readout pretty much mirrors the analogue dial
SFO #348796 18/03/16 05:06 PM
I have 2 temperature sensor, one in the head which feeds the ECU, and one in the coolant pipe as it exits the thermostat, which feeds the dash gauge.
The dash gauge varies quite a lot, but usually shows around 90C in normal driving conditions. The ECU reports a rock steady 100C under more or less all conditions.
I would imagine that the digital temperature readout on the ARP4 could be similar, reporting the temperature in the head, whereas the gauge shows the coolant temperature as it circulates.
