8 members (Hamwich, Sir Percival, SteveT, Chris99, uvk33n, MJF, sid, Saxonian), 207 guests, and 21 robots.
+8Rich 99
John V6 57
Topics49,909
Posts838,132
Chaps,
Thanks for the "heads up" on AFC50. I have just bought a can so will head out to the garage tomorrow (after Sounds of the 60's)and give the seams a spray, not cheap though is it!! thumbs
Reg
Yes, ACF 50 is truly excellent stuff. It's a bit cheaper to buy in larger quantities, I bought a "quart" (which I think is 2 American pints, or just under a litre) from
Transair
Lowebird, a little ACF50 goes a long way.
As recommended on here, I spray some ACF 50 into a container and then use an artists brush to drip the stuff along the seams.
Ian
I boil a pan of water - then put the ACF can in the water - its then easier to apply and runs along the seams a lot better.
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
Both good tips!
Neil
Originally Posted By RoadsterBoy
I have had a Taxy run in Just Jane!
Very envious - trying to persuade Mrs F to treat me for my next birthday.
Costock, UK
Disco 5
When using ACF 50
I use a syringe to apply to either side of the beading - then let capillary action do the rest, much less messy and wasteful!
Mark - No Longer driving
Hello all,
Thank you all of you for your comments and adviced, which are most appreciated. To remove both wings, seem however to be a rather tough issue. I Will try some other method frist, but is wings off The only soloution, then I have to do it. Not now, as I first Will try to get The famous Alf 50 here in Sweden and treat The area with that, but next winter.
Thanks again all!
Ken in Sweden
Ken in Sweden - SM7CQY
Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
SBM Offline
Originally Posted By smsevencqy
Hello all,
Thanks again all!
Ken in Sweden
ACF-50 homepage here
You'll find some dealers nearer to you on there, or try the usual eBay way..
thumbs
