2 members (Image, JMcL),
230
44
Topics49,904
Posts838,083
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Chaps, Thanks for the "heads up" on AFC50. I have just bought a can so will head out to the garage tomorrow (after Sounds of the 60's)and give the seams a spray, not cheap though is it!!
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Yes, ACF 50 is truly excellent stuff. It's a bit cheaper to buy in larger quantities, I bought a "quart" (which I think is 2 American pints, or just under a litre) from Transair
Posts: 3,643 |
Lowebird, a little ACF50 goes a long way. As recommended on here, I spray some ACF 50 into a container and then use an artists brush to drip the stuff along the seams.
Posts: 688 |
I boil a pan of water - then put the ACF can in the water - its then easier to apply and runs along the seams a lot better.
Porsche 981 Spyder V8 Speedster ( 5 years) 4/4 Competition spec (5 years) 4/4 4str Kent ( 10 years)
Posts: 6,538 |
Neil
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
I have had a Taxy run in Just Jane! Very envious - trying to persuade Mrs F to treat me for my next birthday.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
When using ACF 50
I use a syringe to apply to either side of the beading - then let capillary action do the rest, much less messy and wasteful!
Posts: 541 |
Hello all, Thank you all of you for your comments and adviced, which are most appreciated. To remove both wings, seem however to be a rather tough issue. I Will try some other method frist, but is wings off The only soloution, then I have to do it. Not now, as I first Will try to get The famous Alf 50 here in Sweden and treat The area with that, but next winter. Thanks again all! Ken in Sweden
Ken in Sweden - SM7CQY Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Hello all, Thank you all of you for your comments and adviced, which are most appreciated. To remove both wings, seem however to be a rather tough issue. I Will try some other method frist, but is wings off The only soloution, then I have to do it. Not now, as I first Will try to get The famous Alf 50 here in Sweden and treat The area with that, but next winter. Thanks again all! Ken in Sweden ACF-50 homepage here You'll find some dealers nearer to you on there, or try the usual eBay way..
