9 members (Sir Percival, James B W, John Wilcox, Morganmike, BLUE+4, Jon G4LJW, cerealsurfer, MATTMOG, Graham, G4FUJ),
228
49
Topics49,901
Posts838,042
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Is that where you get psi'd Ken?
Posts: 2,583 |
I had this problem a couple of years ago - it was the sender at fault - replaced it then fine for a couple of years - it has just started happening again - although a couple of long journeys seem to have sorted it. I was told not to worry as on my Ford engine it is unlikely to be anything wrong. It just seems strange that the pressure shown seems to bear no resemblance to what the engine is doing. But HEY! - they`re Morgans!
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
Mars Bars are different.. Particularly when deep fried!
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
As Mars is a long way from us perhaps the pressure difference is no bar to using the car.
Posts: 430 Likes: 2
Posts: 430 Likes: 2 |
Thanks a lot for all the technical (and martian) answers ;-)
Have a great (not sunny unfortunately :-/) week end!
vMog is a 2013 +4/ 4 seater, dark red with saddle brown trim, wooden dashboard and console.
Posts: 412 |
I had a similar problem on a 2006 Plus 4. Oil Pressure Gauge would wander up to the top of the scale and sometimes off it in a random fashion. The previous owner said it had been like that since new, he had it checked out by his dealer but was told it was fine and nothing to worry about - and as the engine ran fine he let it be.
I wasn't entirely happy and changing the oil pressure sender unit cured it on my car.
'di te incolumem custodiant'
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
I had a similar issue last year on my Plus8. There are 2 oil pressure senders and the one to the gauge was playing up. From cold it showed correct psi but after a couple of miles it went way up to the top of the gauge. Always ok from from cold but when some heat got to the oil it resulted in this happening. Simple job to replace and now ok. The engine has a second pressure sender for the ecu so no worries with oil as the ecu would have shut the engine down if pressure dropped. For the V8 normal psi is about 40 psi or 3 bar. It drops to just above 15psi(1bar) on idle which causes worries until you realise that is normal!
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
My 1999 +8 goes to 5 bar and doesn't shift much below that even when idling.
Posts: 37,481 Likes: 989
Posts: 37,481 Likes: 989 |
My Plus 8 reads maximum of 4bar running. Cold tickover 2Bar and Hot tickover 1.5Bar. My previous Plus 8 had similar readings.
I'm pretty sure the pressure relief valve operates at 4Bar anyway.
Posts: 381 |
Have a look to:
http://www.talkmorgan.com/ubbthreads.php/topics/189255/Re:_Oil_Pressures_Query#Post189255
Regards 2005 PLUS 4
