0 members (),
315
40
Topics49,844
Posts837,360
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
I was told by my dealer that if you have trouble with the MOT on an SS the factory will fix it, so give them a ring.
Posts: 13 |
Thanks Burgundymog, That's interesting sounds like I better give the factory a call before I speak to the guys at Williams!
Thanks Mart
Posts: 6,538 |
MGW - welcome to TM
Your foray has resulted in a very quick solution - am delighted for you.
The SS is a great car ( I know I almost bought one!!)
Williams are a very good Dealer indeed and so you will soon be sorted!!
Enjoy TM - but BEWARE - it can be very addictive!!
Neil
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
This forum is the only place I know of where you can blow your top on the EU but also get solutions to your ECU problems.
John 1992 plus4 connaught green
Posts: 5,587 |
I was told when my mog was set up on the rr that it wouldn't pass emissions as there was an eratic readout on the sensor but was ok last year , mot coming soon though hope it passes again !
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
Hi MGW welcome to the TM forum ....I'm well used with the P4SS problems having owned one for two and a half years. The first and cheapest fix is to replace the spark plugs ,they will no doubt be the originals which have not been changed or checked. Mondeo or MX5 2.0 .the plug gap should be 130 mm they were reduced to 90 mm for some reason this will reduce hydro carbons and may get you through the MOT without any further rectification . However the ecu set up makes the car run too rich and the injectors are too big causing the car to stutter cough and hesitate at low speed and junctions . It was impossible to keep a steady throttle reading for the MOT between 3000 and 3500 rpm . Williams in conjunction with Omex have come up with a solution but I have not seen any power out put figures or prices. My car was down to 184 bhp ex factory and ran miserably ,so bad I had to call at the factory on the way home to complain about the fumes and poor performance . I had no help from the factory they set up the throttle bodies and told me it was a race car so that's how they are . I found a guy who said he he could fix the problem and he did the car is now as smooth as silk gets a full 204 bhp low emissions ,easy mot pass ,no back fires ,easy starting and when the VVTiming kicks in sounds amazing. The down side is I had to pay for it but it transformed the car . When did you buy the car ? As of 1st OCTOBER THE CONSUMER RIGHTS ACT puts the onus on the dealer to sort out the problem . PM if you would like any more info .
Posts: 13 |
I rang the factory today but they are closed this week ,so I rang Williams they can sort the ecu at a sensible price so I have it booked in with them in a couple of weeks time .Its strange when you are only talking of 60 cars that morgan did not just re-call them in the first place .I think Williams have done a good job in getting over the cock-up .
Good news, hope it goes well.
Hope all goes well and looking forward to further up dates .
Posts: 1,418 |
Williams have 3 excellent mechanics, so your problem WILL be sorted.
Mind you, here is a TM warning :
KEEP AWAY FRIM THE DOGS
(They are the loveliest springer spaniels around. You walk in wanting a tin of Meguires polish and you somehow leave having bought a new Aero! There's no heavy sell < Henry and Paul are genuine guys> but the dogs' "smiles" are irresistible. You have been warned !!)
Cheers
Jeremy
2009 4/4 Sport Green
And nothing else !
