6 members (TBM, Mogdavid, dogmog, Supermog, Ncik P, Mike D), 59 guests, and 41 robots.
+8Rich 104
John V6 66
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,921
Posts838,310
AshleyC, BobtheTrain, pandy, RobertMorgan, shaleafe
Page 28 of 32 1 2 26 27 28 29 30 31 32
Mario,
This is quite a saga -- I certainly didn't expect you would still be fiddling about with cracked exhausts after all this time since the first episode over here in Ireland!!!!!!!
Regards from the PaddyMogs
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Hi Mario, I was only thinking about you over the weekend, I was going to see whether you had made any progress. Looks like you beat me to it.
I can only wish you the best of luck with the unwrapping, and I can't wait to see whether they've listened, for want of a better expression.
which you luck, Mario...if the MK IV does not succed....well, I would consider the Electric 3 Wheeler it doesn't have exhausts (ok, that was black humor,... scared ) never give up oldgit
Cheers,
Georges
Originally Posted By MarioCP
Still with the dealer, still wrapped, no idea what might have changed (if anything) from Mk III spec. Tomorrow they'll be sent to the workshop and I'll get to see them. Will post pictures as soon as possible.
If they don't have the additional flexi-joint up by the silencer, as per the latest G56 pipes, then I'd look to get some welded in myself....! I remain convinced that this is the only workable longterm solution for these designs.
Totally agree. Adding extra strength on the pipe to silencer interface simply moves the inevitable break point to the next weakest location banghead
Could have been solved with v2 confused2
MarioCP Offline OP
MK IV
Pictures taken today. The only visible difference to Mk III is an horizontal weld on the inner side of the silencers (MkIII had this at the bottom).
They'll be fitted into the car tomorrow.
Now for the comparison pictures, in case you don't want to go back a few pages.
Mk III (when new)
Mk III (how they cracked)
I guess we'll have to wait for a couple thousand miles more to know if indeed there's any difference from "previous spec" to "latest spec".
2010 Morgan +4
2014 M3W Brooklands
To be raced
Thank you, I was holding off on ordering the Brooklands until i saw the photos.
kirkusblog.com
1952 Ford 8N
Sorry i must be blind, whats the difference?
Thanks Mario, looks like they weren't following the rest of our thought processes.
I really wish you luck with them and nothing would give me more pleasure than to be proven wrong, but without that extra flexible joint we all feel is the right solution, I fear it's only a matter of time before you head in search of the Mark V.
I am curious to know what the actual physical differences are, or to put it another way, how apparently moving a weld line through 90 degrees can make a difference, if any, to where the splits are occurring? Is something different beneath the skin as it were.
it looks like they moved the weld joint 90 degrees.
kirkusblog.com
1952 Ford 8N
