I am not sure how accurate the oil gauge is....it's a Morgan after all!
It is reassuring to see the pressure though. I treat it as a "normal indicator" and look for changes to tell me of a potential problem.
Same with the water temp gauge.
If the gauges show normal behaviour then fine.
Next time I plug in the diagnostic on a run I will compare lt's readings out of curiosity.
