2 members (sewin, Tony Quinn),
262
53
Posts837,962
Posts: 72 |
I don't lay the car (+4 4 seater) up for the winter and continue to drive it whenever the chance arises. I haven't got a workshop or even a decent garage so anything I cannot do on the drive is done by others. Each year, over the winter, I have a bit of a servicing and updating purge to keep the car in order and this year's work has gone exceptionally well and without spending as much as I expected.
Like a number of members of Anglemog I use Graham King at Chelmsford for most of the work on the car. He does most things Morgan and has worked almost exclusively on the cars for many years, so I make a list of what I want done and get most things done at once. He collects the car, does the work and brings it back to me.
This year he came a couple of times extra to remove the dash for me to re-furbish and after that, to fit it back on the car. He then took the car for my list of jobs which included:
· Supply and fit a Panhard rod. · Full annual service including supply of everything needed. · Prepare car for MOT in March · Clean and check underside after I had gone down 2 miles of track 'unsuitable for motors' on a CVCVC club run in January and scraped the bottom a lot. · Refurbishment of underside paintwork and waxyoiling damaged as above. · Partially repaint interior radio mounting box and heater box. · Sort out erratic slow running. · Touch up and restore numerous chips and marks on exterior paintwork. · Fit new heater vent surrounds (supplied by me) - needed windscreen removal. · Advise on lots of things that I am unsure of.
All of that, and other minor things, cost of all materials including the Panhard rod, three visits to our place (35 mile round trip each time) - total cost, all in, £895.
Now that ain't bad!
I also had a big bad patch of discolouration to find an answer to on the leather roll at the top of the dash, directly behind the steering wheel. I asked around to see what might have caused it and got explanations like the sun, wear, chemicals and various ideas. I even thought of having the whole part re-upholstered but wasn't sure that anybody would have the right shade of Connolly dark blue.
I Googled for 'car leather repairs Essex' and found, among the dross of firms wanting to mend my sofa, 'Kustom Interiors' near Wickford. The owner Jeff Wilks, a third-generation car trimmer himself, said he could fix it and 'bring it along tomorrow' - so I did. He recognised the leather as the same as in a Ferrari he had recently had in and said he had the right stuff (paint?) in the right colour and lustre. While I waited he had a fitter mask up the area and then did the job himself. He made it all look so easy and tackled a few more places, mainly the driver's seat and nearby, that were showing wear. Now it all looks like new and I am very pleased.
They are a brilliant small company that I would recommend to anyone. I was there with the car about an hour and a half, and at the end he charged me £50.
I think I have had really good value for money this year's maintenance and upgrades on the car. Howzat?
Jack +4 4 Seater T16 1996 Indigo Blue 'Mabel' If you can't change it, don't worry about it...
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
Sounds good!!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Sounds like quite a result.
Richard 1976 4/4 4 Seater
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
That place for the leather refurbishment sounds a top find
Posts: 4,896 |
Good stuff Jack, often small local guys are great and give better service.
Adrian
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Good stuff Jack, often small local guys are great and give better service. Yep, definitely! Sounds like a great result.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
These local guys are great if you can find them. We have a local car trimmer who did the edge on my short tonneau. He's a second generation trimmer, and they used to have a business locally. Now he's on his own and works from home, but he does excellent work..
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
There is an established trimmer in Swansea who made a mohair hood for a Morgan last year for under £400! Nice job done too. Old hood used as a pattern. Not mine by the way......still got the Everflex.
There is an established trimmer in Swansea who made a mohair hood for a Morgan last year for under £400! Nice job done too. Old hood used as a pattern. Not mine by the way......still got the Everflex. Crikey that's a good do - who was the trimmer ?
