8 members (Sir Percival, Burgundymog, High Hamster, Bishmog, +8Rich, gmcn, nick w, Luddite),
287
82
Topics49,870
Posts837,673
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Hi
I am assuming that the troublesome joint is between the hose and the tank?
If it hasn't been removed for a long while it is possible the rubber will have adhered to the metal filler neck. It may be possible to break this bond with very careful twisting , but I am guessing that you will have already tried this. You don't want to be using too much force or you will likely weaken the solder flange between the filler neck and the tank surface.
I suspect that heat will make things worse by softening the rubber and increasing the bond between it and the metal.
If you can obtain a spare hose then I have a feeling that the best method may be to make small vertical cuts in the hose until you can actually prise off a strip , this may enable you to twist the rest off , or you may need to continue the process until it does release. Of course this will destroy your hose, but at least you should be able to replace it with the new item.
Good luck
Posts: 17 |
Has anyone got a specific part number for a particularly good-sealing hose? I'm having an ongoing issue with leaks while fueling.
1962 4/4 Series IV B694
Posts: 121 |
Hi Dave I bought one from Morgan spares you should check the gasket for sending unit on top of tank mine was no good and leaking a lot
Posts: 17 |
Thanks for the reply, pcyrgalis...
My issue lies with the filler hose and where it meets the filler tube on the tank. I'm using a marine-grade fuel hose with a hose clamp and don't seem to be able to prevent leaks while fueling unless I use a funnel with a spout that is long enough to get past the spot where the top of the filler tube sits inside the filler hose.
Just curious about others' experiences and fixes.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
It's not ethanol mix perishing various parts is it maybe?
