4 members (TBM, RichardV6, nick w, sprinty), 223 guests, and 94 robots.
Topics49,847
Posts837,389
#353689 06/04/16 06:25 PM
SBM Offline OP
Just been thinking - where does the rear axle in the trads come from..? Is it a common axle through the engine range?
thinking
SBM #353694 06/04/16 06:37 PM
I believe it comes from BTR in Australia
2014 +4, Le Mans Blue / Magnolia
"Meg" the Mog
SBM #353741 06/04/16 08:36 PM
The trad axles are basically the same, but with different ratios. All are the same width.
No longer made in Australia, I just can't remember whether it's now India or Malaysia, or somewhere similar.
SBM #353752 06/04/16 10:05 PM
It's made in Thailand by Spicer Dana. Apart from final drive ratios and/or LSD, the same axle across the Trad range.
SBM #353829 07/04/16 08:58 AM
SBM Offline OP
Thanks Jays.
I've just been having a butchers at the website here and there's a lot of detail in there, especially if you have a limited slip diff..
thumbs
SBM #353831 07/04/16 09:14 AM
Thanks for sharing, so which Dana axle type is used by Morgan?
SBM #353842 07/04/16 10:10 AM
Whilst on the subject, the drain plug on mine was made of blancmange and needed replacement.
Replacement was an M12 X 20MM, 1.75 pitch, flange bolt.
2015 Plus 4 (GDI) Sport Green
SBM #353844 07/04/16 10:14 AM
I wasn't too impressed. My car had to have a replacement half shaft in the first few weeks because of pitting in the section where it is machined for the oil seal.
"Meg" the Mog
SBM #353846 07/04/16 10:30 AM
When changing quick direction i.e. when leaving a roundabout I hear a loud click from the real axle since my car is new. The dealer said it is quite normal and within the given tolerance. Anyone who shares this experience about rear axle behave?
SBM #353859 07/04/16 11:25 AM
My car is in for repair at the moment. From new I've had a knocking from the rear nearside which I believed to be bolts hitting the chasis. However it turns out there's something seriouly wrong in the diff or halfshaft and investigations are ongoing. Car is 2 years old. My kindly dealer has loaned me a fiat 500 for the duration......
Nick
