0 members (),
293
38
Posts837,276
Posts: 429 |
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
That looks good. I went to Malvern and back yesterday in my M3W fitted with the standard Fairbourne screen. The weather was far from ideal 3 wheeler conditions, lots of rain and muck off the road. I had to wipe the screen with my glove frequently to see where I was going, or sit up very straight to see over the top. This lower screen may be the ideal compromise between comfort and vision. As others have said, possibly it could be a little wider to give your hand on the steering wheel some more protection from the slipstream and divert the water away from the cockpit.
Posts: 342 |
really nice  ....would be an alternative if I would need to replace the screens
Cheers, Georges
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
That looks good. I went to Malvern and back yesterday in my M3W fitted with the standard Fairbourne screen. The weather was far from ideal 3 wheeler conditions, lots of rain and muck off the road. I had to wipe the screen with my glove frequently to see where I was going, or sit up very straight to see over the top. This lower screen may be the ideal compromise between comfort and vision....
Interesting. Screen height is clearly very much related to the individual driver's eye-level when sitting in the M3W - I find the standard Fairbourne to be generally below eye-level so don't notice any restricted view. Just goes to show folks should review the different available screen heights for their own personal needs... and not assume any particular screen will work for them!
Posts: 2,539 |
i did not know there were two. I will have to open the box for mine at home and see which one i have.
Posts: 541 |
Nice hugo, the Fairbourne GTS screen it looks very smart.
I see you have the stage ll kit at lest the pipes. Did you have to make the heat shield brackets or did it come with the kit.
Thanks, Timothy's
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
Posts: 215 |
also like this alternative
Posts: 902 |
also like this alternative Looks great, scuttle mounted aero screens. They are not a direct fit are they? Any more photos from cockpit side? Also polished cowl or custom made? More photos please.
Posts: 6,538 |
Oooo that is just sooo smart - I do like that!!
Neil
