1 members (Carbuilder), 220 guests, and 62 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,603
Page 11 of 12 1 2 9 10 11 12
Is this Bobby Darin`s car?
Yes! it is the DiDia "Bobby Darin" car!
kirkusblog.com
1952 Ford 8N
Originally Posted By Chris99
Originally Posted By nippymog
Hi
I bought from here , select 6.4mm , 1/4" on the drop down list.
They snap into place using pliers nicely.
http://www.ebay.co.uk/itm/261568319605?_trksid=p2060353.m2749.l2648&var=560440528305&ssPageName=STRK%3AMEBIDX%3AIT
Thanks Nippy - set ordered thumbs
Finally got round to fitting these and found the 1/4" / 6.4mm were a bit tight on the shaft of the Dzus fastener. They wouldn't slide freely so I've now tried the 7mm version and they seem fine.
Definately easier than mucking about with the standard wire clips thumbs smile
Red Leader drive
Am I the only person who had no problem "mucking about" with the stock wire clips?😬
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Quite possibly hide
Give it time and you'll be swear at them like the rest of us.
It only seems to be the cowl/bonnet fasteners which cause a problem. The boot/trunk ones seem OK, probably because the leather straps flex to help line up the dzus.
Red Leader drive
I must be missing something in this thread... Looked through all 11 pages. How are circlips helping with the fitting of the front dzus fasteners?
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
There are little pieces of metal that hold the fasteners in place and when you add the G56 spring kit the tension from the springs can pop the original clips off. The larger circlips replace the original retaining clips and don't slip off.
Charlie, Former Editor
thumbs
However I had a couple of the original wire clips come off even before I fitted the G56 spring kit.
Time will tell whether the E clips will last any longer but they feel pretty secure so far.
Red Leader drive
You can find a picture from the Under Bonnet Storage Locker heute:
http://www.morgan-motor.co.uk/mmc/shop/i...amp;order=price
Or have a look at this picture.
