7 members (Beard, Mark Simmons, CooperMan, DalesPlusFour, jbk, Morganmike, Barkbark), 349 guests, and 24 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,198
Georgetoad, woolfie
#355734 13/04/16 08:42 PM
Andy Offline OP
The wipers on my 2011 roadster have stopped returning to the parked position when I do a 'flick' single wipe and when I do a windscreen wash. Does anybody know what it is that controls this function such that I can try some diagnostics/replacement?
Andy
Andy #355741 13/04/16 08:57 PM
Usually a microswitch on the wiper motor/gearbox...
Good luck. smile
Andy #355777 13/04/16 10:46 PM
Check the multipin connector to the wiper motor and the one behind in the steering wheel shroud. Give them a clean and a squirt with switch cleaner.
Andy #355842 14/04/16 08:59 AM
Used to be a classic sign that the motor had lost its earth, we used to put a quick fly lead on the motor (ground its casing with a wire to the engine block, if it moves the arms to the park position (ign on and wipers stopped part way as you describe of course) then clean all earths. Cleaning the block connectors is very good advice also, as is check the one under the motor as it gets full of trapped water.
BR Colin
Andy #355875 14/04/16 11:48 AM
+1. Clean the earth.
Andy #355985 14/04/16 06:24 PM
Andy Offline OP
Thanks all for the input I will check the earths and connectors first
Andy
