9 members (Graham, G4FUJ, DCH, flyfisher, JMcL, Robbie, vincentvg, ScotiaSteve, Luddite, MATTMOG),
241
46
Topics49,863
Posts837,553
Posts: 14,009 |
Simon, you can access the battery by either lifting the ply rear shelf and under tray or if you lift the carpet from the vertical panel behind the passenger seat, you'll find an alloy plate which can be unscrewed. The battery is directly behind that.
Posts: 37,420 Likes: 978
Posts: 37,420 Likes: 978 |
Some of the older Morgans (mine included) have a battery isolation switch fitted which will prevent this. If security (insurance) is not an issue you might consider having one of these fitted by your agent or DIY. This is in itself a very good security device and I always use it when playing away from home. http://www.holden.co.uk/displayproduct.a...mp;pCode=SSB112The ECU soon relearns once it's temporary store has sorted itself out on power restoration and a few miles 25 or so. Hamwich's answer sounds like a really good alternative too given that you have no power outlet or sun. p.s. In my earlier reply I assumed you had a Gel battery fitted in the engine bay I hadn't realised they had reverted to somewhere sensible.
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
The switch h is a good idea
Posts: 1,162 Likes: 5
Posts: 1,162 Likes: 5 |
my favourite option is the battery isolation switch .. most convenient
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Main reason for asking is that it's apparently quite common for Morgan's to have a flat battery after more than 1 or 2 weeks of non use -- at least that is what I have read on here recently. This is surprising to me.
Really..? That surprises me too.
Posts: 34 |
I just started my car after 5 months of winter storage with no battery conditioner. The car started easy on first try, partly because of the battery isolation switch.
Ragnar 2000 mod +4
Posts: 5,587 |
Sounds like some of us need a battery isolation switch fitted asap !
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
You might want to take a look at one of these we have a few at work and they'll jump start a diesel transit. The problem will be getting to the battery Battery boosters
Slowly going green
Posts: 22,362 Likes: 353
Posts: 22,362 Likes: 353 |
That really is black magic................
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
You might want to take a look at one of these we have a few at work and they'll jump start a diesel transit. The problem will be getting to the battery Battery boostersthe n No problem just clamp the positive crocodile clip to the heavy black lead to the starter motor, and the negative to a point on the engine.
