8 members (Ruut Bianchi, Themorganeer, Morganmike, BillHart, Chris Cosher, MogOnTheMove, Ubiquitous, GrumpyPa), 313 guests, and 40 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,325
Members9,215
Page 31 of 39 1 2 29 30 31 32 33 38 39
Try using some tape around the rear bulkhead edges, it reduces the dust considerably.
Plates look good. Did you use any kind of adhesive behind them?
@ planenut
jup, will do with heat resistant tape (3M™ Polyester Tape 8905)
@ hbatts
those plates are the stock ones from the factory! they are made of very thin aluminium. so no wonder, the 3 screw holes (exhaust mounts) are getting bigger and bigger with all the vibrations!!!
i will change them with stainless steel ones.
ok folks....had a big mechanic-day today. after my big exhaust header crack, the factory sent me (after 12 weeks!!!) a new header. it's a completely new design! the front piece which goes into the cylinder head, is not so short anymore and it's inserted in the header pipe. 6cm deep. the old solution was welded onto the pipe, the new one is inserted in to the pipe. new weld is MIG and not Tig anymore. no way, it can crack again at this point!!! the rest of the header pipe is more or less the same design....length and angles. the pipe walls itself are slightly thicker. 1 or 2 tenth of a millimeter.
back on the road since today. we will see......
Thanks for info swissghost and glad your car is back on the road.
Not sure if you can tell from this image of my car completed this week, but if possible could you advise if it appears to have these new construction front pipes?
It does.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Thanks Ken smile
yes, thats the new construction!
Look at Swissghost's excellent drawing. Note the weld OUTSIDE of where the header goes into the jug. :-)
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
only two badges allowed on my 3 wheeler!
